golf
golf
#1 Post by rich. »
one of my clients owns a 2004 golf diesel with 7500 km & the rev counter has packed up & he wants to repair it.. any ideas/links i could pass on chaps?
Re: golf
#2 Post by tractorman »
Just to get the ball rolling:
The dash "blew" on my '96 Passat some time ago and it was an epic to get it sorted - VW had to make a new circuit board for that particular car as a special order. I suspect newer Golfs are even worse - my 2002 Mk IV (TDI) had codes on pretty well everything behind the dash that "had" to be programmed by a VAG dealer (though there are lot of indys with the necessary gear nowadays).
I suspect that you'll need to go to someone who can read the error codes to find the exact cause of the problem - IIRC, the rev counter is "controlled" by the main computer (but I could be very wrong!).
I suspect the MkIV forum will be best for Golf stuff:
http://uk-mkivs.net/forum/29-mkv-mk5-go ... lus-jetta/
They seem less stuffy than some other VW forums!
Re: golf
#3 Post by rich. »
thanks mate :thumbs:
