Early Javelin Restoration
- Grumpy Northener
Re: Early Javelin Restoration
Quite a bit more cutting later and I was ready to commence rebuilding Leading edge of the A post was removed More laminated rust
- Grumpy Northener
The front outrigger required some modification before a good fit to the chassis was achieved Leading edge of the A post was fabricated and let in along with the front outrigger being tacked into position Repair section for the inner wing / wheel arch fabricated / welded / cleaned up
- Attachments
- WP_20130818_008-001.jpg (55.2 KiB) Viewed 1689 times
- Grumpy Northener
The sill could now be trial fitted With minor trimming the panel dropped into alignment Repairs for the floorpan and lower section of the A post are next on the list
- Attachments
- WP_20130818_011-001.jpg (70 KiB) Viewed 1689 times
- Grumpy Northener
Floor pan patterned Rotten section removed & top of new outrigger welded in
- Grumpy Northener
Repair section fabricated Welded in & cleaned up
- Grumpy Northener
Front outrigger fully welded in & inner wing / wheelarch spot welded to new floor pan section Front sill tacked into place ready for trial fitting of doors
- Grumpy Northener
Doors hung & sill alignment checked
- Grumpy Northener
Lots of fettling required in order to achieve the correct gapping This requires quite a lot of brute force so first I need to get some strength into the sills at the
A & B posts
A & B posts
- Grumpy Northener
Looks simple but quite a complex repair to the lower A post completed - next is to get further strength into the B post by completing the sill repairs in that area
- Grumpy Northener
More progress Rear sill & B post repairs in the making Front sill / B post repairs complete
