Early Javelin Restoration
Re: Early Javelin Restoration
#201 Post by Grumpy Northener »
Quite a bit more cutting later and I was ready to commence rebuilding
Leading edge of the A post was removed
More laminated rust
#202 Post by Grumpy Northener »
The front outrigger required some modification before a good fit to the chassis was achieved
Leading edge of the A post was fabricated and let in along with the front outrigger being tacked into position
Repair section for the inner wing / wheel arch fabricated / welded / cleaned up
#203 Post by Grumpy Northener »
The sill could now be trial fitted
With minor trimming the panel dropped into alignment
Repairs for the floorpan and lower section of the A post are next on the list
#204 Post by Grumpy Northener »
Floor pan patterned
Rotten section removed & top of new outrigger welded in
#205 Post by Grumpy Northener »
Repair section fabricated
Welded in & cleaned up
#206 Post by Grumpy Northener »
Front outrigger fully welded in & inner wing / wheelarch spot welded to new floor pan section
Front sill tacked into place ready for trial fitting of doors
#207 Post by Grumpy Northener »
Doors hung & sill alignment checked
#208 Post by Grumpy Northener »
Lots of fettling required in order to achieve the correct gapping
This requires quite a lot of brute force so first I need to get some strength into the sills at the
A & B posts
#209 Post by Grumpy Northener »
Looks simple but quite a complex repair to the lower A post completed - next is to get further strength into the B post by completing the sill repairs in that area
#210 Post by Grumpy Northener »
More progress
Rear sill & B post repairs in the making
Front sill / B post repairs complete
