MGB GT 2.8 V6
crabo249
Re: MGB GT 2.8 V6
#11 Post by crabo249 »
I used the same vynil to cover the seats and interior trim
Side panels
Side panels
Rebuild March 2012 x4 010.JPG (52.24 KiB) Viewed 5061 times
The rear seats have had new foam inserted
Rear seats
Rear seats
Rebuild May 2012 013.JPG (57.11 KiB) Viewed 5061 times
The drivers/passenger seats have had new foams and the frames repainted
Drivers seat
Drivers seat
Rebuild May 2012 019.JPG (58.28 KiB) Viewed 5061 times
Crabo249
Cuurent cars:
1997 Mercedes C180 Auto (Daily driver)
1978 MGB GT for fun (when it's done)
3xpendable
Re: MGB GT 2.8 V6
#12 Post by 3xpendable »
Lovely job :D
2019 Ford Mustang Bullitt.
2022 Alfa Romeo Guilia
harvey
Re: MGB GT 2.8 V6
#13 Post by harvey »
crabo249 wrote:The original alternator bracket was cut to size using an angle grinder and used to mount the alternator,all that's needed now is a custom tension bar
You should be able to alter the alternator to bring the adjustment bolt across closer to the engine. You move it round by 120 degrees anti-clockwise as you look at that pic. The ear that has the adjuster on now becomes the bottom pivot, and the bottom pivot moves around to the top. It will be a lot neater to look at, and judging by the high standard of the rest of the work you've done, it will fit in perfectly when it's done.
crabo249
Re: MGB GT 2.8 V6
#14 Post by crabo249 »
Harvey thanks for the advice i will try to get it done this weekend :)
Crabo249
Cuurent cars:
crabo249
Re: MGB GT 2.8 V6
#15 Post by crabo249 »
Havn't worked for a while on the car due to a bad back ( Old age ) But since September i've managed to complete a few more jobs.
The goal is to get the car running under her own power by Christmas :D
Stripped and painted the block and gearbox ready for new seals and gaskets
14 september 011.JPG (61.35 KiB) Viewed 4954 times
New seals and gaskets for the engine
29 September 2012 005.JPG (68.4 KiB) Viewed 4954 times
New clutch added and gearbox bolted to engine
29 September 2012 009.JPG (66.22 KiB) Viewed 4954 times
Crabo249
Cuurent cars:
crabo249
Re: MGB GT 2.8 V6
#16 Post by crabo249 »
Engine bolted into place
14 October 2012 001.JPG (102.85 KiB) Viewed 4952 times
Exhaust bolted on
Stainless steel exhaust added
14 October 2012 003.JPG (100.71 KiB) Viewed 4952 times
A couple of fans added to keep things cool
14 October 2012 006.JPG (106.79 KiB) Viewed 4952 times
Crabo249
Cuurent cars:
crabo249
Re: MGB GT 2.8 V6
#17 Post by crabo249 »
I've started wiring things in and have also re-routed the brake lines through the wing of the car
This weekends plan is to connect up the water hoses and starter motor wiring
Still a way to go but i'm making progress :)
Crabo249
Cuurent cars:
JensenProject
Re: MGB GT 2.8 V6
#18 Post by JensenProject »
Terrific job, I bet this will fly with that V6 in it :o. Look forward to seeing the finished car!!
crabo249
Re: MGB GT 2.8 V6
#19 Post by crabo249 »
Hooked up the starter motor, exhaust and hoses just before Christmas and fired her up
Rebuild December 1 003.JPG (69.57 KiB) Viewed 4831 times
Ran a bit rough but not bad for the first fire up, switched off the engine and it wouldn’t start again
Had a sulk covered the car and left it till February :cry:
Traced the fault to a broken wire on the Distributor and a faulty ignition relay
Fired her up and drove her for the first time under her own power since 2010 :D
1st drive
1st drive
MGB First drive 2013.jpg (16.78 KiB) Viewed 4831 times
Prop shaft has had to be made as my attempt at making the shaft wasn’t very good (banana shaped)
Straight through exhaust sounds great
Rebuild March 31 011.JPG (61.27 KiB) Viewed 4831 times
Crabo249
Cuurent cars:
crabo249
Re: MGB GT 2.8 V6
#20 Post by crabo249 »
Sprayed the inside and fitted soundproofing
Rebuild March 16 2013 014.JPG (64.73 KiB) Viewed 4828 times
Bought some wheels for refurbishing
New wheels
New wheels
Rebuild March 21 003.JPG (62.13 KiB) Viewed 4828 times
Once the weather improves I’ll start on the body work
The car has picked up a few dents from being stored off site plus i sprayed the primer on to thick and after drying for a week it cracked all over
Rebuild March 31 008.JPG (62.11 KiB) Viewed 4828 times
Crabo249
Cuurent cars:
