MGB GT 2.8 V6
crabo249
MGB GT 2.8 V6
#1 Post by crabo249 »
I have always liked the MGB GT so in 2010 i took the plunge and bought a 1978 model off Ebay :roll:
This is how the car looked when i picked her up
Outside the carwash for a wash and brushup as the car had been standing for 9 months
Full of enthusiasm the stripdown begins
also discovered lots of melted wires and a fair bit of rust
Crabo249
Cuurent cars:
1997 Mercedes C180 Auto (Daily driver)
1978 MGB GT for fun (when it's done)
crabo249
Re: MGB GT 2.8 V6
#2 Post by crabo249 »
Off to the welders for a marathon session
Cut out all rusty metal and welded in some new tin :geek:
New sills and castle rails welded on with wing trumpets,rubber bumper mounts have been cut off to convert to chrome bumpers
New rear wings wheel arches and chrome bumper valance added
Crabo249
Cuurent cars:
crabo249
Re: MGB GT 2.8 V6
#3 Post by crabo249 »
With the welding finished its time to start putting the car back together :D
I've lead loaded all the welds to try and use as little filler as possible :geek:
Crabo249
Cuurent cars:
crabo249
Re: MGB GT 2.8 V6
#4 Post by crabo249 »
The front crossmember,antiroll bar,and suspension parts have been sandblasted & powder coated
All new polybushes,replaced wheel bearings added drilled and grooved disks new calipers and brake hoses
Chrome bumper height springs were used , the shock absorbers are refurbished units from Moss UK as the originals were in a very poor condition
Front cross member
Front cross member
:P
The rear axle has had the same sndblast and powdercoating as the front and new leaf springs have been attached
Back axle
Back axle
A chrome bumper valance has been added and the back axle attached to the car
Adjustable shocks have replaced the old lever arm ones
The underneath of the car has had a couple of coats of Schutz to keep the tin worm at bay
Rear valance
Rear valance
Crabo249
Cuurent cars:
crabo249
Re: MGB GT 2.8 V6
#5 Post by crabo249 »
Added the front crossmember to car so i now have a rolling chassis
Front suspension looking all nice and shiny
Petrol tank has bee cleaned and powder coated
MGb on four wheels at last
Crabo249
Cuurent cars:
crabo249
Re: MGB GT 2.8 V6
#6 Post by crabo249 »
Brake lines have been fitted so the car can stop when i push it around the unit :roll:
Brake lines fitted
Brake lines fitted
The panel gaps on the doors needs a bit of work so that'll keep me busy for a while :?
n/s door
n/s door
o/s door
o/s door
I have been lucky egnough to store my car in a local garage unit so if i do have any problems there is always somebody there to ask :ugeek:
Crabo249
Cuurent cars:
crabo249
Re: MGB GT 2.8 V6
#7 Post by crabo249 »
Took the car back home to my garage to have a go at spraying
Covered everything with plastic sheets waited for a warm day and had a go
Hanging up ready for paint
Took of the wings doors and tailgate to spray seperately
Not bad for a first attempt
:D
Crabo249
Cuurent cars:
crabo249
Re: MGB GT 2.8 V6
#8 Post by crabo249 »
With the car now in undercoat to keep the rust at bay it was time to refit the engine
A scrap sierra came my way with a lovely 2.8 v6 cologne engine :idea: i wonder if it will fit
Colopgne 2.8 v6
Colopgne 2.8 v6
Rebuild January 016.JPG (62.17 KiB) Viewed 7426 times
fits like a glove
The o/s exhaust manifold was to close for comfort and the n/s hit the chassis rails :oops:
O/S Manifold
O/S Manifold
Rebuild January 020.JPG (57.86 KiB) Viewed 7426 times
n/s manifold
n/s manifold
Rebuild January 021.JPG (59.38 KiB) Viewed 7426 times
Time to make custom manifold and exhaust
Crabo249
Cuurent cars:
crabo249
Re: MGB GT 2.8 V6
#9 Post by crabo249 »
The original alternator bracket was cut to size using an angle grinder and used to mount the alternator,all that's needed now is a custom tension bar
alternator
alternator
rebuild february 2012 009.JPG (64.44 KiB) Viewed 7424 times
Alternator bracket
Alternator bracket
rebuild february 2012 010.JPG (62.43 KiB) Viewed 7424 times
As the engine sits a little higher than the old 1800 unit i've put an air scoop in
Hood scoop
Hood scoop
Rebuild March 2012 x3 003.JPG (57.16 KiB) Viewed 7424 times
Crabo249
Cuurent cars:
crabo249
Re: MGB GT 2.8 V6
#10 Post by crabo249 »
I havn,t been able to work on the mechanics of the car for various reasons, so i thought i'll have a go at the interior.
Automotive Vynil was bought from ebay and with lots of spray glue and a staple gun off i went
The first job to tackle was the headlining so i used the old boards as templates and added new foam
Headlinging board and foam
Rebuild March 2012 x3 034.JPG (51.11 KiB) Viewed 7423 times
I used ivory headlining material
Ivory headlining
Ivory headlining
Rebuild March 2012 x3 035.JPG (57.8 KiB) Viewed 7423 times
C post sections
C post sections
Rebuild March 2012 x4 009.JPG (62.2 KiB) Viewed 7423 times
Crabo249
Cuurent cars:
