Hi
I hope someone can help me. I have a 1954 Austin Somerset which has had flashing indicators fitted, but I would like to reinstate the semaphores to work at the same time.Is anyone please able to explain or preferably show me a diagram of how to accomplish this.
Looking on the internet I found a diagram, but it used two separate flasher relays (one for each side), This seems strange, but is it correct? Would I need to fit a relay to reduce the current at the indicator switch?
With kind regards
Malcolm
Trafficators with flashing indicators
Re: Trafficators with flashing indicators
It really depends on how the flashers were wired, but the normal way is to connect the flasher unit input to ignition live and feed the output via the switch. You can't use the switch output for the semaphores because this would be flashing and it would also overload the flasher unit, so the diagram you saw is probably correct. You would need to connect ignition live directly to the switch centre contact and then connect one flasher unit and one semaphore to each output of the switch. Using a relay is a good idea as the switch load would be increased, you would need one per side.
Pretty sure this has been discussed on our A30/A35 Owners' Club forum a few times .. the A30 and early vans had semaphores too ..
Some others have gone a stage further and fitted flashing LEDs to the semaphores to "emphasis their presence" ...
Hi
Many thanks
Many thanks
