oops.
oops.
#1 Post by UKJeeper »
Driving home last evening (in the V40), and the gear lever felt a little 'odd'. And then....
:shock:
Re: oops.
#2 Post by rich. »
:lol: :lol: :lol:
Re: oops.
#3 Post by JPB »
:shock: What are the chances eh? Bloody Belgian monkey metal.
Re: oops.
#4 Post by GHT »
When I saw the title "Oops," I thought that Rich had been busy again.
Re: oops.
#5 Post by Luxobarge »
Oops indeed. However, it looks as if that'll come apart from the top so you could weld it back - I know that's what I'd do! After all, if you replace the part then it's all got to come apart anyway, and if you do it yourself at least you'll be sure of the weld quality eh?
I'm a Volvo fan (I have a V70T5) but Volvos aren't what they used to be......
Re: oops.
#6 Post by UKJeeper »
Sorted! Got pointed at a breakers in Erith (Kent) by a fella on the Volvo forum. Pull it yourself (Fnarr!) place. Cost me... a fiver!
Result!
Re: oops.
#7 Post by JPB »
Luxobarge wrote: Sat Jan 28, 2017 9:08 am ....Volvos aren't what they used to be......
It could be argued that they haven't been for ages. My 142S sheared its parking brake lever from the tube that carries the mechanism across to the driver's side of the seat, a simple fix, as the tube and the lever could be removed without disconnecting the cables from the yoke which, bizarrely, ran down the centre of the car, it appeared never to have been welded properly as the lever left no traces of penetration on the cross tube, so I ought to have been pleased that it had lasted over twenty years at that point, but the rest of the 140 series was just so overengineered I found this quite disappointing. I'm actually more surprised that the O/P's modern Japanese Volvo suffered from a similar failure as I've never met such a thing on any Mitsubishi, not even my own Outlander which was much the same car but with 4wd and a detuned version of Evo 8's engine.
Must've been a Friday car? They like their Friday, thae Belgians.
Re: oops.
#8 Post by GHT »
JPB wrote: Sat Jan 28, 2017 7:03 pmIt could be argued that they haven't been for ages. My 142S sheared its parking brake lever from the tube that carries the mechanism across to the driver's side of the seat, a simple fix, as the tube and the lever could be removed without disconnecting the cables from the yoke which, bizarrely, ran down the centre of the car, it appeared never to have been welded properly as the lever left no traces of penetration on the cross tube, so I ought to have been pleased that it had lasted over twenty years at that point, but the rest of the 140 series was just so overengineered I found this quite disappointing. I'm actually more surprised that the O/P's modern Japanese Volvo suffered from a similar failure as I've never met such a thing on any Mitsubishi, not even my own Outlander which was much the same car but with 4wd and a detuned version of Evo 8's engine.
Is there a translation from gobble-de-gook to English that I could look up in order to help me decipher this post?
Re: oops.
#9 Post by Grumpy Northener »
I would not worry about it GHT - it involves a car that was built after 1908 so you won't like it :D
Re: oops.
#10 Post by JPB »
The O/P's car has suffered from a similarly sub standard weld to the one that allowed my 142S' parking brake tube to come free from the handle. Is that simpler enough for your limited resources, Gramps?
Thank goodness that modern cars have a left foot operated parking brake, it must make life so much easier for the average 107 year old man.
:P
Oh, and yes, this:
Grumpy Northener wrote: ...I would not worry about it GHT - it involves a car that was built after 1908 so you won't like it :D
