Does UK Jeeper know anything about axle end float.
The axle is limited slip differential which has a Mopar additive in the oil.
Dana 44 axle.
Is this a c clip axle and how much end float on the half shafts is normal
Bob
Rear axle end float Jeep Cherokee
Re: Rear axle end float Jeep Cherokee
If it's a D44 it's not a C Clip. That was only inflicted on the D35's. But is this on your XJ? They have D35's.
As far as free play, you mean in and out or turning? About a 1/4" on in and out, and about an inch or so on turning.
