Got a question for the builders / house restorers among you
Sorry, this is going to be long winded,
My old house is a single story "cottage" built about 200 years ago, with solid stone walls, the walls are of the local flagstone laid quite roughly one slab atop another and varying in thickness tremendously from about an 1/2 inch to 5 inches thick. The walls are a good 2 foot plus deep and were originally built with lime mortar and left bare. The stone while similar to sand stone is very dense and hard.
The house was "modernised" in the 70's and then a harled finish (pebbledash) chucked up to cover all the sins. Then re dashed about ten years ago, but inspection shows that to have been thrown over the existing dash.
So, following this winter I have a couple of walls with large hollow spots behind the rendering and some spalling, in effect the entire coating needs to come off and be redone on these walls.
Ideally I'd be looking at a lime render or simply removal of dash and then pointing as more sympathetic but....
1.. I've never lime rendered,
2.. I cant do a pointing job as there turns out to be some unsightly concrete blocks making good the odd area at the roof line and given very tight mortar joints it would have to go on and be a brush finish anyway.
3.. Cost is going to be an issue, a very big one as we may one day have to consider selling up and houses are worth very little up here.
So, I have worked with brickies in the past and rendered with Sand and cement, so it will probably have to be this method, unsympathetic as it is. What I need is the best mix possible given the construction, I'm thinking Sharp Sand and Builders sand with cement and a little lime thrown in for good measure.
Can any of you advise the best ratios, for scratch coat and then finish coat, I know we have to get weaker as we go,
And a question that nags me, Why do we always use two coats, why can I not simply throw one coat about ten to 15 mm thick following the shape of the wall and stones for a rough rustic finish which could then be painted more in keeping with the style of finish of the old lime renders and limewash / whitewash effect that were once common on rubble built houses. I considered the monocouche type renders as seem to be popular elsewhere but I think cost will be prohibitive.
Thanks Chaps, all advice appreciated.
