battery drill
battery drill
#1 Post by rich. »
hi chaps, i have an autofeed screwdriver with dead & dying batteries.. any idea where i can get the cells to repair the batteries myself.
its a concept 14.4volt. ive had them apart before to resolder a conection so changing the cells should be a doddle :D the company doesnt sell spares or replacements
Re: battery drill
#2 Post by JPB »
At work, we get refills for the older laptop batteries and the mobile test gear from THESE. Click on "bespoke applications" to get an idea of the many different one offs they can supply. I had a bunch of cells from there for my Bosch drill a few years ago and that's still going but be aware that other parts of the battery pack can fail as well as the cells. Sometimes you'll need to check regulator packs (where these are part of the battery itself) and thermocouples.
Re: battery drill
#3 Post by rich. »
thanks mate, i thought i might get away with just changing the cells.. checking thermo doodads etc sounds complicated
Re: battery drill
#4 Post by JPB »
It's no less straightforward than swapping out dead cells and if the cells are Lithium based, then doing the safety gear while you're in about at it is essential. With NiMH and NiCad you would be safe with simply swapping cells. ;)
Re: battery drill
#5 Post by rich. »
ill have a lookie but im sure its not lithuanian type battery :D
Re: battery drill
#6 Post by TerryG »
This is how you do it:
https://www.youtube.com/watch?v=96foswY ... gRsnWjSrlA
I don't suggest trying some of the things in his other videos though.
Phil P
Re: battery drill
#7 Post by Phil P »
Sometimes battery packs off other makes fit. It might sat Black & Decker on the case but very often the guts are the same as lots of others. Badge engineering is every where. Somebody out there will know what fits what and which is the cheapest.
sierra3dr
Re: battery drill
#8 Post by sierra3dr »
Have a look on ebay for 14.4 battery. Looks like black&decker and Milwaukee use the same
Re: battery drill
#9 Post by JPB »
I'd be very surprised if DeWalt and B&D things aren't also interchangeable.. ;)
Re: battery drill
Rich - Just had the same problem with my Dewalt 18v NiMH batteries that powers both my cordless combi drill and my impact driver - first battery died some time ago but now the second one has also died - new Dewalt batteries are £100 each with a new drill / impact driver + 2 x batteries = £250 but after a quick search found this company - link below - replacement batteries are £35 free p + p - so just ordered 2 and will see how I get on with them - just got to find someone that can dispose of the old batteries now
http://www.allbatteries.co.uk/
