Thought I'd post some details of my TR6 restoration for you to have a look at.
It's been ongoing for around 5 years now (bought the car as an abandoned resto in Nov 2005 - Bit of a basket case, and what had been done had been done very badly... as is often the case I guess!).
Full pics on my Flickr page as per my signature below.
This is how it looked when I first saw it:
Didn't look too bad when it arrived home:
But once I was able to start poking around, I soon realised how much of a state it was in. What was expected to be a case of just finishing off the bits that had been started turned into a full strip down and nut-and-bolt restoration.
The Chassis was weak with rust and kinked at the front o/s corner. Fuel and brake lines rotted through, Body was full of patches welded 'pigeon poo' stylie over rust, Engine full of gloopy old oil that had probably been in there since 1981 when the last tax-disc expired. It had apparently been repainted (the story was that's why the previous owner had to sell it... he had to raise cash to pay the painter... that's the story I was spun, but it turns out the paint was wafer thin and had just been blown on over the transit primer on the few new panels with little, if any, prep).
So.. Strip down commenced, and I was soon ready to separate body and chassis. As it always seems you can never rely on helpers being around when needed, this was easilly achieved single handed with a 2-ton engine crane, some lifting straps, and a few trestles:
Body restoration ensued - cutting through the floors and restoring back end then front end, then joining the two halves back together again with new floors and sills.
Chassis restored and jigged, then built up with new / restored running gear:
Engine stripped and rebuilt
Body stripped, etch primed then painted
Then mounted back on the chassis, and engine, gearbox, propshaft, loom, fuel, etc all connected up.... and finally running after being out of action for 30 years
Engine running clip here:
http://www.flickr.com/photos/darren-cam ... 681163702/
Body panels were all stripped and etch primed late summer last year. Plan for this summer is to get them painted and refitted.
All being well, I hope to have the car finished this year. Then I'll have time to crack on with the VW Bay Window restoration!
