Fifi and Friends
Xantia-nut
Fifi and Friends
#1 Post by Xantia-nut »
Ay up!
Recent activity in our workshop has shamed me into doing summat with my Pride and Joy.
Shiny, innit?
Shiny, innit?
This was an ubershed when it arrived. The paint was shocking pink and very matt - I will post a piccie when I get my hands on the Centre's camera! Now look at it. I had to do summat:
Feel free to say eeuuuuggghh!
Starting Pt.JPG (117.9 KiB) Viewed 3688 times
The dents will be sorted later but 1st I need to see 'em. This car was unwashed for 3 years at one point. The "scut" behind the rear window was weathered matt and the paint an intaglio of little scratches.
Shaun hard at work.JPG (121.44 KiB) Viewed 3688 times
One of our trainees hard at work, putting the final polish on the paint. Looking good!
See the next instalment for the finished job.....
If in doubt, give it a clout!
1993 Citroen Xantia 1.8i LX
Xantia-nut
Re: Fifi and Friends
#2 Post by Xantia-nut »
And now the finished article!
Fifi finished.JPG (110.52 KiB) Viewed 3685 times
Shiny enough for you?
The work was carried out at my new Workplace, Timken Vocational Training in Wolverhampton. Appropriately, we occupy the former Body Finishing Shop of the old Sunbeam works on Upper Villiers Street. And guess who now owns the Sunbeam trademark?
Fifi comes home, in a way.
The Porsche 924S and an old Vauxhall van in the background. These vehicles are dismantled then reassembled by our trainees. They do find the 2nd part of the job harder than the 1st......
Xantia-nut
#3 Post by Xantia-nut »
Ay up!
As promised, piccies of the Porker pre-polishing. Try saying that with a stutter! Camera obtained piccies downloaded and modded.
After a day's hard work - just final hand polish needed.
The scrapman has supplied the front bumper today but - it's busted and missing lights from one end. :cry:
Xantia-nut
#4 Post by Xantia-nut »
Ay up!
Meet another of Fifi's friends - Shaun's Peugeot 306 cabrio. This had a loud, gruff voice caused by a major leak at the downpipe joint which we sorted.
Shaun hard at work.JPG (113.6 KiB) Viewed 3656 times
Shaun removing the downpipe. Luckily not a vid - it would have got me banned! The ball-headed bolts were seized solid and sheared off. We then had to tap the cast iron "bowls" from the manifold. With a 4lb hammer, deep impact socket and a long extension bar! :twisted:
The problem.JPG (116.91 KiB) Viewed 3656 times
And there you see the prob. A previous owner had slackened off the manifold bolts to give it that "Bad Boy" farty sound but was too tight to buy a "performance " exhaust. The constant vibration had worn away the cup.
Anyway, this was welded up and ground smooth using my modeller's rotary tool and mounted grindstones. Thing is, I now need a new set of mounted grindstones!
One more for the moment: Fifi at home, all shiny and clean. Now raindrops cascade from the roof under braking! Haven't had that for a while....
Fifi at home!.JPG (123.59 KiB) Viewed 3656 times
Xantia-nut
#5 Post by Xantia-nut »
Ay up!
We have a new addition to our workshop fleet - a Daewoo Matiz. I drew the short straw - I had to drive the thing back to base.
However, I got a suprise. I was determined to hate it. Small, lacking charisma with 800cc of raw chutzpah! I found instead that it was as much fun to drive as a Mini, fairly comfy even for my rather corpulent 6 foot 3 inch frame (the vendor suggested a shoehorn!), cornering as if on rails and, provided the revs were kept up, pretty nippy. And amazingly rorty, sounding like a V12 when it hit peak revs! Kinda like a cross between a Mini and a Fiat 500.
Piccy to come later - guess who didn't have his blithering camera on him!
alfaSleep
#6 Post by alfaSleep »
Xantia-nut wrote:Ay up!
How was the change?...... Linkage on the box is listed as being [almost]..NOT.. quite 'rifle bolt' :?:
That said..... I was quite happy with a 'local' renter who supplied a 5door, c/locking... :shock: ..., when I needed wheels whilst having the head off my 2.0 LPT 9000 skimmed.. So fast - So thirsty.. .. a few years ago now..'only in dreams' these days, sadly.... :cry:
alfaSleep
Richard Moss
#7 Post by Richard Moss »
Xantia-nut wrote: The work was carried out at my new Workplace, Timken Vocational Training in Wolverhampton. Appropriately, we occupy the former Body Finishing Shop of the old Sunbeam works on Upper Villiers Street. And guess who now owns the trademark?.
I know the area - there are loads of great little businesses in that area. I used to live in Castlecroft.
Xantia-nut
#8 Post by Xantia-nut »
Ay up!
The 'change was as good as a Ford - say no more! Grab a gear, wait for it to roar, grab the next. Snickety-snick.
OK, wheel bearings are VERY vocal and the brake pedal is very low. Sortable!
Xantia-nut
#9 Post by Xantia-nut »
Ay up!
Some more piccies:
The workshop.JPG (124.09 KiB) Viewed 3579 times
1st off, a piccie of my playpen. Occasionally into this sheltered world of dubious classic-ness comes a little rain in the form of an LDV minibus.
2nd, the Rover.
Rover 216.JPG (97.15 KiB) Viewed 3579 times
Tatty but in reasonable fettle mechanically. Should be great for our kids!
And finally.....
The Beast!!.JPG (114.64 KiB) Viewed 3579 times
Curb your over-enthusiasm at the back there.....
#10 Post by JPB »
I rolled one of those once, albeit not the Daewoo-badged version. It deserved to die though the hire company's complaints department suggested that it didn't. They were wrong! :evil:
I only had it while one of my A60s was VOR with a dead torque converter, given more time I'd probably have found a way to burn it too.
