finding air leak on brakes???
caveman
#1 Post by caveman »
hi i am having trouble with the brakes on my 58 single circuit vw beetle, i have replaced everything slave cylinders master cylinders all flexy pipes and all hard lines . also the 3 way joint at the back was replaced , i am using my freinds suction bleeder which attaches to the nipple and sucks fluid through rather than forcing it through via the resivoir. it will not bleed correctly and just passes a small amount of fluid and mostly air .... so i am thinking that i have a leak somewhere... how do i pin point which component is leaking as none are seeping fluid ?????????
help please its driving me mad!!!!!!!!
Re: finding air leak on brakes???
#2 Post by Luxobarge »
Are you sure the air is coming from the system itself? The problem with suction bleeders is that they can suck air in from around the threads on the bleed nipples - pressure bleeding systems avoid this problem. Try liberally coating the threads around the bleed nipples with thick grease and see if it's still showing air bubbles.
grumpy2
#3 Post by grumpy2 »
I've never had any great success with this type of bleeder. Try the old fashioned way of getting a helper to press the pedal. I had all sorts of problems doing the clutch slave on my mg, sorted in 5 mins with the help of a pedal pusher!
caveman
#4 Post by caveman »
thanks this sounds like it may be the problem as ive changed everything else!! lol ill have a go tonight and let you know
