hi everyone,
does anyone know if there is any truth in the things i have been hearing about setting up a ford flathead v8 distributor,my father in law says they have to be set up in a jig for proper running.im on restoring a 1950 version and i cant get a spark out of it for love nor money
can anyone help
thanks
ford flat head v8 distributors
Re: ford flat head v8 distributors
They only thing I have experience of a flat head dizzy was on a late 40's V8 Pilot.
IIRC the bottom plate was earthing out the contacts, and preventing a spark.
Hope this helps in some way.
Mal.
Mal.
The twin points set up. best thing to do is start simple, close the points and with the ignition on flick them open with a screwdriver and see if they spark at all, if they do, go forward if they dont, go back.
The job is a whole lot easier with the radiator out.
Does anyone do an electronic conversion for these?
im building a distributorless system for the car,based on the ford edis 8 system from american fords and possibly late jag v8 engines,so if it works i will publish a link to show how i did it
thanks to everyone who has helped
I have an EDIS on my Mercedes 6.3 . It has unleashed even more power from this already powerful device.
I grew up with Ford sideys in New Zealand and in my teens I ran a '39 Ford standard with a '48 mercury engine. The best V8 dissy was always the crab and yes ,both the diving bell (or rugby ball) dissy and the crab dissy should ideally be set up on a Ford Distributor jig. .The engine you have has a pathetic dissy which is best gotten rid of and an EDIS used instead. Even in the 1950's they gave trouble and were a retrograde step compared with the earlier dissys which would run for years without a hitch.
Ah i see, ive used EDIS in the form of a megajolt kit and most parts came from here...http://trigger-wheels.com/store/?gclid= ... fAodYFhsmg
