Is this too far gone?
#1 Post by TerryG »
I have fancied a 2 door range rover for YEARS (but can't afford to buy a good one). I have found this on the bay of e
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0694636605
Does it look too far gone to save? The only time i have held a welder is a TIG at the PC workshop a few years ago.
Sills are avaliable off the shelf but the chassis looks like it has more air than metal at the back and A post rust is a bit worrying.
Re: Is this too far gone?
#2 Post by rich. »
yes. what you would spend renovating you could buy a good 4 door cheaper.. better still get a fourtrack although they rot too.
#3 Post by TerryG »
I have 2 4 doors at the moment (one will be going on saturday though) both cost less than a grand to buy in reasnoble order but there is something about an early 2 door car that appeals. I don't want to end up with a pile of rust on the drive though. I get enough grief for the one i use every day!
Mattcortes
#4 Post by Mattcortes »
The early ones are lovely. Certainly not too far gone. Go on you know you want to.
Matt
1978 Reliant Scimitar SS1
1986 Mini City
1990 Mini Equinox
1969 Hillman Imp
1969 Morris Minor 1000
Scarab Formula Vee race car
#5 Post by rich. »
could you find a good body & fit it to a reasonable 4 door chassis?
Willy Eckerslyke
#6 Post by Willy Eckerslyke »
IMO that's way too far gone unless you're planning a complete rebuild on a replacement chassis. If the bits we can see look that bad, there'll be an awful lot more grief under the surface - and don't forget that under all that bodywork there's a steel frame rusting away. I wouldn't touch it with a barge-pole, but then I'm not the greatest fan of Range Rovers. (I could never come to terms with the fact that I'd be driving the mechanical bits of a Land Rover, with a whole tonne of unnecessary bodywork sitting on top.)
ajsphead
#7 Post by ajsphead »
Definitely restorable without too much hassle. I have a mate who's been driving round in one far worse than that and just working his way around the holes as he gets to them. Remember you need to have the space to separate chassis and body. Chassis rails are good thick steel when you get to it, so it's not a big faff to weld. If you don't fancy the rear cross member, just get another one with a decent one, chop and weld.
Early 2 doors fetch good money, so altogether I'd say it's worth it.
Anthony
1992 Saab 900 Turbo 160 5dr 'Eric'
1992 Saab 900 N/A 3dr 'Bertie'
1985 Rover SD1 Vitesse 'Stan'
2003 Honda VTR 1000 'Ronnie'
#9 Post by TerryG »
Someone's put the steering wheel on the wrong side!
I have definitely seen worse ones (my 4 door is bad but at least the chassis is solid).
Under cover i only have space for the body or chassis at once as my mog lives in the same garage and i wouldn't put it outside. I do want it but i don't want to end up with a bottomless pit. I haven't seen a 2 door project come up for a while then i find 3 all in the same day!
A rebuild on a new chassis would be an option but at £1500 off the shelf it would make it prohibitively expsneive.
This is one of those times when your heart says "you know you want it" and your brain (and bank manager) says "steer well clear!"
It would be a superb toy but i don't fancy a 10 year restoration project like some you see.
#10 Post by rich. »
you can always swap the steering back to the correct side :D
