Hard to see but someone has been overplating rust on the lower wheelarch
Again hard to see in the image but the flange where the wheelarch meets the floorpan is tissue paper thin
And after chasing the rust back to sound metal - this is what came out
New floor section provides flanges for lower wheelarch to connet to
Managed to get the section for the inner wing made up - but it shall have to wait for my next workshop visit for welding in
These little clamps come in really handy when undertaking repair sections like this
Just place the pins in the clamp tounges and tighten up
Welded / cleaned back - floor pan flange is spot welded to the lower of the repair section - outer wing mounting bracket re welded to completed repair
Managed to to obtain a nice fit with the floor repair section
Next was a small amount of grot on the cill step adjacent to the A post
New section ready for welding
Completed
I had given the outrigger a quick look over before commencing the floor & wheelarch repairs and with exeption of a small section on the very end of it - passed it fit for service - obviously my quick look over - was too quick - has I got in to it it was was obvious that it was hiding a nest of rust on the inner face
I originally planned to section it and fabricate a repair - but the deeper I dug the worse it got
I already had a complete outrigger supplied by the club (Jowett Car Spares)
One dead outrigger
In my haste I had already welded the repair section for the floor to the old outrigger So now I had to carefully unpick the welds on the new panel
Last edited by Grumpy Northener on Tue Jan 29, 2013 11:01 pm, edited 1 time in total.
Keith sandblasted the area that is hidden when the outrigger is in place - I then sprayed the area with a zinc rich primer
With the primer dry - I sealed any seams that would be awkard to access once the new outrigger was fitted
Seam sealer was not used when the cars were first built in the early 50's - but it will not prevent me from using it this time around - I will go through and seal the rest of the shell once all the repairs are complete and the shell has been bare metaled
Trial fit on the outrigger which required a little bit of trimming / reshaping to ensure a good fit
