206
Re: 206
#61 Post by gazza82 »
Dick wrote: Tue Mar 05, 2024 7:16 pm After a visit to the mechanic it's showing po170 and po130 codes.. I'm going to give it a dose of injector cleaner and check if anything is amiss.. ive already had a look but can't see anything.. would it be worth changing the lambda sensor?
I found my 206 (and my daughter's slightly older 206CC) notoriously hard to get a proper code reading. Using "off-the-shelf" diagnostic readers often presented codes that looked feasible but were in fact totally wrong. I don't believe that PSA complied properly with the EU rules and the EOBD standards and the use of an ECU and BSI, combined with the later Plex wiring system, meant that you need a specific code reader. I used the PeugeotPlanet software on a Win95 laptop and a PSA specific Sealey diagnostic unit .. sometimes even they disagreed! :shock:
(Being a French company, I bet PSA would expect the EU to go easy on them and ignore their transgressions .. and the French MEPs and PM would fight their corner with the usual Gallic shrug of the shoulders :roll: ).
On my Alfa 156 I once had isses with the lambda which every now and then would turn on the EML and throw up lambda related codes. That had been fitted by my Alfa specialist when I had a fueling problem. I checked the part number and it matched my car but when I checked the actual specs I noticed the NTK version that had been fitted differed to the Bosch lambda sensor in the ohm ratings. I swapped out the lambda for a Bosch Universal LS615 unit (same body, you carefully cut and re-used the original wiring and plug - no soldering either) and the EML stayed off, and no more codes. And even better, the MPG figures improved ...
Re: 206
#62 Post by Dick »
Gazza you fill me with confidence :lol:
We have a mechanic friend who has plugged in his works machine.. this gave us more information but nothing definitive
Po170 fault dosage carburant
Po130 fault oxygen sensor circuit
Po131 low tension oxygen sensor...
He seems to think the first fault in the list may create all the other faults..I'd like your opinion..
Re: 206
#63 Post by gazza82 »
A faullty oxygen/lambda sensir would cause overfueling.
Re: 206
#64 Post by Dick »
gazza82 wrote: Wed Apr 03, 2024 12:03 pm A faullty oxygen/lambda sensir would cause overfueling.
Thanks for the info mate, I'll get it done and see what happens :thumbs:
Re: 206
#65 Post by Dick »
Update on the 206, I put another can of cleaning product in the tank and ordered the new oxygen sensors so headlight bulb went pop in protest... what an absolute pain in the arse to fix!! I had to remove all the fixings just to get at the connector.. the light won't come out as with a clio so a 5 minute job takes 2 hours.. running round in the car with the engine light glowing for the past 2 months I'd collected the sensors €136 thank you very much I'd planned to fit them yesterday but got tied up with a mates suzuki samurai exhaust joint.. went out shopping for the kids in 206 and the engine light has gone off.. I'm happy but now I'm the proud owner of 2 brand new sensors that will sit in the shed until something else goes wrong...
Re: 206
#66 Post by rich. »
Update, car has been running pretty well , almost.. Thursday morning I started it and a loud mechanical ticking noise had a look and couldn't see anything amiss.. took it to see a mechanic but by the time I arrived it had stopped.. Friday morning same story, drive for a couple of km and the noise stopped.. spent Saturday fiddling remove the cam belt cover, run the car. Nothing wrong with the belt removed the alternator belt started the car cold Sunday no noise.. as I was putting everything back together I spotted lumps of the old belt melted on the crank pulley.. after much fiddling all clean and reinstalled the belt.. noise has vanished.. tried again today and the problem seems to be solved. Now I need to find the source of the squeal from the gearbox at 90/100 kmh.. I changed the gearbox oil this weekend but it hasn't cured it....
Re: 206
#67 Post by rich. »
Car has been fine, ticking noise from belt or tar deposits have stopped . The squeal from the gearbox however is getting worse.. yesterday I went out to the car put the key in the ignition and turned it on as I would with the truck (too early/I wasn't awake). This gave me the loud squeal I thought was coming from the gearbox even though the engine wasn't running.. I've opened the bonnet and had a listen but I couldn't find where it is coming from.. so I'm guessing it's electrical, does anyone have any ideas where it is coming from?
Re: 206
#68 Post by gazza82 »
Fuel pump?
Re: 206
#69 Post by rich. »
Thanks, it's coming from under the bonnet.. there looks to be an electric fuel/injection pump on the right side under the bonnet.. tomorrow I'll have more time to investigate.. if I can find my photo account thing I'll post a couple of videos..
Re: 206
#70 Post by rich. »
