206
Re: 206
#51 Post by Dick »
Luxobarge wrote: Tue Jan 23, 2024 10:07 pm
Dick wrote: Tue Jan 23, 2024 9:27 pm Light came back on after 20 km :cry:
And what are the codes now?
The same :cry:
Re: 206
#52 Post by Dick »
Living in the countryside, the road is a bit muddy, car was making a rubbing noise.. had a look and the rear wheel arch liner was full of soil. After a bit of a fiddle I got it off and dug 8 kg of soil out... further investigation I noticed that there is no liner a the top so soil is going up to the top of the c post.. this is the same both sides .. is this normal??
Regarding the engine light, it still on and booked for a visit with a mechanic when he has time..
Re: 206
#53 Post by suffolkpete »
Yes that is normal, only the front has liners.
Re: 206
#54 Post by Dick »
suffolkpete wrote: Sat Mar 02, 2024 9:13 am Yes that is normal, only the front has liners.
Thanks mate, I've been looking under random 206s and they are all the same.. what a bloody silly design! :shock:
Re: 206
#55 Post by Luxobarge »
Dick wrote: Sun Mar 03, 2024 7:49 am .. what a bloody silly design! :shock:
Let me translate that for you:
"It's French.... :roll: "
Re: 206
#56 Post by Dick »
Luxobarge wrote: Sun Mar 03, 2024 8:34 am
After creating baffling pointless paperwork its another French superpower
Re: 206
#57 Post by Dick »
After a visit to the mechanic it's showing po170 and po130 codes.. I'm going to give it a dose of injector cleaner and check if anything is amiss.. ive already had a look but can't see anything.. would it be worth changing the lambda sensor?
Re: 206
#58 Post by Dick »
Update, I've given it a couple of doses of injector cleaner and a damn good thrashing.. its running OK if a little lumpy on idle.. someone mentioned the egr valve.. could that cause the problem??
Re: 206
#59 Post by suffolkpete »
Dick wrote: Mon Apr 01, 2024 9:14 pm Update, I've given it a damn good thrashing..
So you are Basil Fawlty :D
Re: 206
#60 Post by Dick »
suffolkpete wrote: Tue Apr 02, 2024 9:39 am
:lol: :lol:
