Early Javelin Restoration
Re: Early Javelin Restoration
#171 Post by Grumpy Northener »
Not posted for a couple of weeks as I was a main player in the staging of our annual Jowett international rally in Basingstoke (pics to follow soon) so what's been happening in the meantime ?
Well I managed to locate a scrap trolley out of a skip which provided wheels & stub axles for a body shell trolley so I set about fabricating a couple of axles - front one will be steering
#172 Post by Grumpy Northener »
This now gives the ability to move the shell around the workshop once all the welding is complete and the body shell comes off the chassis tilter
#173 Post by Grumpy Northener »
It also means that the project can attend our national rally
Where it provided the topic of many conversations with Javelin owners / restorers alike
#174 Post by Grumpy Northener »
The rear shocker mountings were all but hanging off - this is the nearside one
Mounting removed completely along with a poor repair to the rear seat upstand which was cut out and refabricated
#175 Post by Grumpy Northener »
I managed to clean the old mounting up and once I had fabricated a new back plate the mounting was rewelded into place along with new strengthening webs
And here is the latest addition to the workshop organisation department - a new tool trolley - well used but cost nothing (it's actually a supermarket dairy trolley) keeps everything to hand and saves having to rack it all on shelves at the other end of the workshop.
Topaz
#176 Post by Topaz »
Grumpy Northener wrote: And here is the latest addition to the workshop organisation department - a new tool trolley - well used but cost nothing (it's actually a supermarket dairy trolley) keeps everything to hand and saves having to rack it all on shelves at the other end of the workshop.
Ha! I like that idea - my son works at Tesco and drives a 1979 Mini - I'll have to see if he can tow one home for me as it won't fit in the boot :D
We already have the base of one of their large 'cages' used for stock delivery - a lorry crushed most of the superstructure and so we rescued the base and castors - very handy for resting his Mini engine on and moving it around the garage.
Mike
#177 Post by Grumpy Northener »
A suspect area was noticed adjacent to the shocker mounting point - this is a double skinned panel and sure enough when tapped with the hammer - through it went
Carefully cut back to sound metal with the air saw
Inner side complete
Last edited by Grumpy Northener on Sun Jun 02, 2013 8:48 am, edited 1 time in total.
#178 Post by Grumpy Northener »
Outer skin prepped for welding in
Cleaned back
#179 Post by Grumpy Northener »
Next on the list was to sort the O/S/R inner wing section around the shroud area to which the rear outer wing is bolted
Not has bad as the nearside
Another one off the list
#180 Post by Grumpy Northener »
I rotated the car on the tilter to access the offside shocker mounting
Again all but hanging off - look carefully and you can see cracks in the welds all around the mounting areas
Mounting removed
No end of bodged welding attached to the mounting
