Some of you may recall that a good few months back among a whole load of computers I was gifted by a near lifelong friend included as a star attraction a very tidy Apple II Plus. Which while sound, had some major stability issues. Up till a few days ago I had been struggling a little to figure out how to approach it. My hunch was that we had some duff memory, but I didn't really know how to confirm that. Until a couple of days back when I stumbled across a video on YouTube by Adrian's Digital Basement where he mentioned a diagnostic utility called Cillin II. He was mainly using it for disk mechanical diagnostics in the video, but mentioned in passing the other features it packed in - including a memory test feature. Cue a frantic scramble on my part to find a disk image - which thankfully was readily available. Which I could use easily thanks to the Floppy Emu. Finally I was set up for some actual diagnostics to try to get this old crate working properly again probably for the first time since the 90s.
Hey look, we have memory errors!
These were all clustered between addresses $8212 and $BDDE. Which is quite helpful as that narrows it down to a handful of chips on the board, on the upper row of the group in the white rectangle below.
Cue a bit of old fashioned deductive reasoning and experimentation.
Hey would you look at that...
A clean memory test - after running for about 30 minutes. Which is a good 15 minutes longer than I've had it running even a BASIC prompt without falling over to date.
Additional good news...
That's another clean memory test for the 16K of memory on the language card - which I'd previously not been able to even get the machine to boot with installed.
The culprits?
Two dead memory chips with a stuck bit. One from the motherboard, one on the language card.
This was quite exciting news as it meant I could actually start doing some proper testing of the hardware as it was for the first time running in a stable fashion - and had the software to do it.
Disk drives are an obvious target, I have six of them. Four Apple Disk IIs, one Super IV and one Cumana (as usually seen attached to BBC Micros).
The Cillin diagnostic suite actually has some pretty advanced disk testing facilities. Step one is to format a disk for use...
Which went without incident.
Probably the most useful test I think is one which is labelled as the random read/write test. This randomly seeks and reads/writes to every sector on the disk - a good workout for the mechanism which may have been dormant for a couple of decades, and a good way to weed out any mechanical issues.
I'll take that! Each "P" in that image indicates a "pass" result for a successfully written and read back sector on the disk. I hadn't even so much as cleaned or looked at that drive or the disk I used there, so I'm well happy with that. Something I hadn't realised until just now is that aside from the initial head bang when it homes itself is how quiet these drives are. The head seek is nearly silent, the spindle motor is more noticeable than the head positioning motor.
The other five will need to be tested over the coming days.
At least I do actually have a functioning system I can do testing and experimentation with now.
Having an easy way to test memory allowed me to ascertain that I do have a full board worth of functioning memory for my "parts" machine too after scavenging a couple of 4116 chips off a spare language card. A dead memory chip on there (Mostek chip, no surprises there then) right at the bottom of the stack would definitely explain why it wouldn't boot when I last tested it. So this thing may well also live to fight another day yet.
This machine is a compete Bitsa, assembled entirely from scrap and found parts back when these machines were worthless, but it would be really nice to actually get it up and running too. Aside from seeing if it will now boot I'll not likely be doing much investigation on that in the near future though, the main system will be the main target for now.
Quite looking forward to seeing what this machine can do now.
