In the workshop at present
- Grumpy Northener
Major delouse / dust down of workshop whilst the bodyshell was outside - round 2 sees the remaining panels put into primer as of last night with along with a load of minor / small metal parts / fittings - this just leaves about 10 internal metal window surrounds which have been bare metaled but require priming at some stage but I need to concentrate on the outer / closure panels first
- Attachments
- 20170316_202748.jpg (55.23 KiB) Viewed 44178 times
- 20170316_202741.jpg (54.81 KiB) Viewed 44178 times
- Grumpy Northener
Bonnet, boot, osr wing & several minor metal parts prepped & painted
- Attachments
- 20170317_233226.jpg (60.49 KiB) Viewed 44161 times
- 20170317_233217.jpg (61.66 KiB) Viewed 44161 times
- 20170317_233212.jpg (58.03 KiB) Viewed 44161 times
- 20170317_200643.jpg (53.18 KiB) Viewed 44161 times
- Grumpy Northener
We have a logistics problem with getting the car to the NEC for the show - space is tight in the van so the rear axle - built up as a sub assembly was fitted to the car on a temporary basis it will be removed when we get to the show - same thing for the front suspension - although for movability the transit axle / wheels will stay on the front - the red wheels on the back axle are temporary and will be exchanged for a set of rims that I will put into the green body colour
- Attachments
- 20170317_233314.jpg (59.05 KiB) Viewed 44161 times
- 20170317_233300.jpg (63.23 KiB) Viewed 44161 times
- 20170317_233252.jpg (65.2 KiB) Viewed 44161 times
- Grumpy Northener
My fellow Jowett sparing partner Keith was with me on Sunday so I took full advantage of him - once I had fitted the bulkhead webbing & bonnet hinges he gave me a hand to fit the bonnet
- Attachments
- 20170319_114537.jpg (65.54 KiB) Viewed 44161 times
- 20170319_112344.jpg (69.11 KiB) Viewed 44161 times
- 20170319_105302.jpg (71.73 KiB) Viewed 44161 times
Last edited by Grumpy Northener on Mon Mar 20, 2017 7:36 am, edited 1 time in total.
- Grumpy Northener
Must invite more visitors as the workshop becomes more civilised with tea & biscuits, front bumper bar irons were fitted followed by the bumper & over riders - with some minor shimming we got the fit aligned - bumper was then removed for fitting at a later date
- Attachments
- 20170319_130008.jpg (70.57 KiB) Viewed 44161 times
- 20170319_145710.jpg (59.52 KiB) Viewed 44161 times
- 20170319_145703.jpg (76.18 KiB) Viewed 44161 times
- Grumpy Northener
Bonnet was then flatted & polished
- Attachments
- 20170319_203631.jpg (67.95 KiB) Viewed 44161 times
- 20170319_171257.jpg (61.12 KiB) Viewed 44161 times
- 20170319_163942.jpg (62.39 KiB) Viewed 44161 times
- Grumpy Northener
The boot lid was fitted along with the rear wings - wings fitted on a temporary basis to check for the bumper iron fit and alignment (these travel through apertures in the wings) the irons required quite a lot of fettling / shimming along with the brackets - the rear of the car had suffered a shunt at some stage in it's life and whilst I had all the panels realigned whilst undertaking the restoration I knew that the bumper mountings / brackets to the rear would require some reworking to get the bumper alignment / end wrap alignment equal to the curvature of the rear wings - The wings need to come back off to enable the piping bead to be fitted but I don't intend to undertake this until the show - again for logistical reasons the wings will go on the car to the show as this the safest way of transporting them without damaging the panels / paintwork - osr wing was flatted and polished - I flatted the bootlid but I have a paintwork defect that I am not happy with hence the boot will be repainted
- Attachments
- 20170319_203705.jpg (66.83 KiB) Viewed 44159 times
- 20170319_171110.jpg (65.88 KiB) Viewed 44159 times
Last edited by Grumpy Northener on Mon Mar 20, 2017 7:39 am, edited 1 time in total.
- Grumpy Northener
Couple of images detailing the torsion bar suspension set up - rears travel horizontally behind the rear seat whilst the fronts pick up from the lower suspension arm and run down the inside of the chassis rails
- Attachments
- 20170319_204154.jpg (57.66 KiB) Viewed 44159 times
- 20170319_204202.jpg (59.8 KiB) Viewed 44159 times
- 20170319_204144.jpg (63.79 KiB) Viewed 44159 times
- Grumpy Northener
Not too much done on the Javelin so far this week as I had a modern booked in for repair - none the less I have managed to get the remaining 5 panels that were in primer flatted and ready for paint - the modern is finished - just have to give it a quick wash off and go and deliver it and I can start to get the remaining panels looking shiny this afternoon
- Attachments
- 20170321_201736.jpg (63.78 KiB) Viewed 44131 times
- Grumpy Northener
All 4 doors prepped & painted along with the nearside rear wing
- Attachments
- 20170324_072355.jpg (70.26 KiB) Viewed 44115 times
- 20170323_174642.jpg (56.94 KiB) Viewed 44115 times
- 20170323_174632.jpg (58.35 KiB) Viewed 44115 times
- 20170323_174623.jpg (56.66 KiB) Viewed 44115 times
