In the workshop at present
- Grumpy Northener
Loads more done - what was left of the headlining was removed and retained for pattern, window trims removed - nearside windows & front windscreen removed - screen aperture is somewhat very crusty though - I will have a look at how I make it go again in the morning
- Attachments
- 20170304_193037.jpg (58.05 KiB) Viewed 14130 times
- 20170304_190425.jpg (74.58 KiB) Viewed 14130 times
- 20170304_142838.jpg (65.58 KiB) Viewed 14130 times
- Grumpy Northener
Windscreen aperture is in a right state - called my fellow Jowett club member and serial Bradford owner - he has several aperture panels salvaged from scraped vans but are all in the same state as this one - so nothing for it - it's going to have be repaired - took an age to get off - all the woodscrews to the ash frame were rusted solid - I ended up drilling the heads off the majority - the bottom rail is in good order which is just as well has this is major job to remove as it is spot welded to the bulkhead panel - I opted to cut the panel at a 45 degree angle at the bottom of the A pillars - had to take care releasing from the ash frame as quite a few of the major joints have let go - the glue has simply given up and I shall have to remake the joints but did not want to distort or damage the frame any more than I really had to - add to this the fragile state that the panel is in in the first place and it was a kid gloves task
- Attachments
- 20170305_151951.jpg (63.22 KiB) Viewed 14110 times
- 20170305_151917.jpg (48.82 KiB) Viewed 14110 times
- 20170305_151901.jpg (65.58 KiB) Viewed 14110 times
- 20170305_151815.jpg (78.1 KiB) Viewed 14110 times
- Grumpy Northener
First job was to brace the panel up so that the repairs could commence - I welded a horizontal brace to the bottom of the A pillar sections and was able to bolt a second brace through the wiper spindle holes to the upper section - started on the pillars - managed to just get away with cutting out the flat section of the aperture just before the return rebate and welded this in - once dressed back I formed a angle section and spot welded this insitu as per the original - the angle is then drilled through and retains the panel to the frame - both front & rear of the completed pillar section shown with old cut out section alongside
- Attachments
- 20170305_172110.jpg (70.07 KiB) Viewed 14109 times
- 20170305_172030.jpg (61.29 KiB) Viewed 14109 times
- 20170305_155500.jpg (71.47 KiB) Viewed 14109 times
- Grumpy Northener
Got both pillars done and one of the radius sections
- Attachments
- 20170305_200331.jpg (74 KiB) Viewed 14109 times
- 20170305_200254_002.jpg (57.05 KiB) Viewed 14109 times
- 20170305_194248.jpg (70.95 KiB) Viewed 14109 times
- Grumpy Northener
Meanwhile - I had removed the surface rust from the radius roof side panels with a rotary wire brush on the angle grinder but need to treat the deep pitted rust so a liberal coating of Deox Gel then covered with a thin polythene and left for 24 hours - results to follow
- Attachments
- 20170305_110500.jpg (115.86 KiB) Viewed 14109 times
- 20170305_105806.jpg (111.17 KiB) Viewed 14109 times
- 20170305_105817.jpg (67.9 KiB) Viewed 14109 times
- Grumpy Northener
Rear load area cleaned out - some of the planking will require replacement - has will the rear lower cross member to the ash frame - nearside rear door pillar will also require a repair section
- Attachments
- 20170305_103512.jpg (61.26 KiB) Viewed 14109 times
- 20170305_103457.jpg (71.11 KiB) Viewed 14109 times
- 20170305_103447.jpg (73.82 KiB) Viewed 14109 times
- 20170305_103435.jpg (70.99 KiB) Viewed 14109 times
- Grumpy Northener
Pic of the rear side frame now free from it's upper cover panels gives a better idea of the construction - outer side panels are alloy - Pretty obvious statement on the badge - more to follow later today
- Attachments
- 20170305_104135.jpg (79.97 KiB) Viewed 14109 times
- 20170305_103441.jpg (72.71 KiB) Viewed 14109 times
- Grumpy Northener
More progress on the Bradford - windscreen aperture repaired in sections prior to forming the top angle rail - shrunk to obtain slight radial curve
- Attachments
- 20170306_162351.jpg (73.98 KiB) Viewed 14088 times
- 20170306_135913.jpg (71.02 KiB) Viewed 14088 times
- 20170306_130828.jpg (74.1 KiB) Viewed 14088 times
- Grumpy Northener
Windscreen aperture completed but work still required on the A pillars and the roof edge in order to complete the panel - I will get done what I can but now have to concentrate on getting the Javelin painted - I put the last of the Javelin panels into polyester this evening
- Attachments
- 20170306_191818.jpg (60.15 KiB) Viewed 14088 times
- 20170306_162446.jpg (75.77 KiB) Viewed 14088 times
- 20170306_162433.jpg (65.07 KiB) Viewed 14088 times
- Grumpy Northener
Guide coat applied to panels prior to them being setaside / guide coat applied to bodyshell
- Attachments
- 20170307_111841.jpg (58.34 KiB) Viewed 14072 times
- 20170307_105011.jpg (53.35 KiB) Viewed 14072 times
- 20170307_105005.jpg (55.3 KiB) Viewed 14072 times
