In the workshop at present
#21 Post by Grumpy Northener »
Nearside inner & outer sill completed
#22 Post by Grumpy Northener »
These old things really do like to rust, don't they?
Well funny you should say - New front panel arrived today so I cut & removed the old one to find this can of rust worms
#23 Post by Grumpy Northener »
One hell of a good example as to why you should never dismiss / leave a leaking windscreen to fester or put off as one those jobs to do later - the front inner panel requires replacement along with the screen retaining edge - I will probably have to remove the dashboard to access / facilitate the repair - the lower sections that abut to the cab floor are just flat so I can piece these in from sheet steel - fortunately the inner panel & retaining edge are available as replacements but by the time these and the front panel are fitted there is not much change out of £800 - £1000 - all for the sake of a having a windscreen resealed - an expense of probably £25 to £50 at the most
vulgalour
#24 Post by vulgalour »
Another great example of why shiny paint doesn't always mean solid bodywork too! That' rather a lot more rot than it looked like could be hiding in there.
#25 Post by Grumpy Northener »
So whilst waiting for delivery of the inner front panel I tackled the side trim retaining rail on the nearside rear wing
the rail was totally rotten - so window out and rail removed
New rail welded in
new side trim (old one was again rotten) trailed for panel fit
#26 Post by Grumpy Northener »
Back to the front panel
some clown who had undertook a previous repair thought that applying a thick bead of sealer between the inside of the screen rubber and the dash panel would resolve the water ingress issues :twisted:
Annoyingly the new inner front panel comes without the dash mounting brackets and these have to be recovered - cleaned up and spot welded to the new panel - I say annoyingly has this would add all of £1.50 to the price of the panel if was done at the factory - it's bad enough that a non over sized / non over complicated steel pressing is £150 in the first place
tacked in and ready for trial fitting of the outer panel
#27 Post by Grumpy Northener »
Front panel trial fitted / clamped in place - importantly -the windscreen was refitted to check the aperture - hell of a fight to get the panel fitted around the A pillars - screen removed and both panels fully welded - welds dressed back and just minor finishing required tomorrow before I fit the lower closing panels to the bottom of the A pillars
vulgalour
#28 Post by vulgalour »
Once again, a shame that your work is all hidden when you're done. What was panel alignment like on these? It doesn't look like you had too much of a fight in the pictures.
#29 Post by Grumpy Northener »
Fitting the front panel was a swine - it's way too narrow in width - I had to open each side up and work the A posts back to get it to slip over - net result is that the fact that you can now drive a bus through the door gaps and I am going to have to put a few hours remedial work on the aperture gapping to get them to look anything like what they should - they were not brilliant before I started and the doors have been replaced with pattern replacements at some stage in the vans life which are not a brilliant fit - none the less I will still have to do something about the front aperture gaps - I will post a couple of images up when I get on to them - I have an old trick in mind for sorting them ;)
#30 Post by JPB »
Chris, a lesser man would have set the damned thing on fire by now! :lol: Your patience is impressive.
I'm looking forward to seeing your approach to adding metal to door edges. Does the work involve building up the leading or trailing edge of a door with welding rods. Or maybe with human bones carved out of the people who sign off these ill-fitting modern repro parts as fit for purpose.
:twisted:
