meanwhile we have managed to register it with only 1 trip to the prefecture
clio diesel
Re: clio diesel
i tried to record the bearings but nearly ended up in the ditch...
Re: clio diesel
Rich, are you sure it's bearings not noisy tyres? i had thought the rear bearings on my focus were tired but the noise is actually goodyear efficient grip tyres which are quite noisy. If I put my spares on (Dunlop SP Sport) they are really quiet.
Re: clio diesel
rich. wrote:there is no play in the bearings but they are making a noise.. i will be changing them anyway, just not this month![]()
My new Uniroyals had me on the verge of having a student take the Toyota's diff out and check the plates for signs of a Joe Dolce single, but would a tyre be noisy if the wheel was off the ground though? Rich, maybe your tyres are full with gravel or similar..TerryG wrote:Rich, are you sure it's bearings not noisy tyres? i had thought the rear bearings on my focus were tired but the noise is actually goodyear efficient grip tyres which are quite noisy. If I put my spares on (Dunlop SP Sport) they are really quiet.
Apologies if I've assumed incorrectly that your stating that there wasn't any play would have meant lifting the car to check, maybe the car has a wheel bearing wear-o-meter on the dashboard?
Re: clio diesel
I was assuming (possibly incorrectly) that assuming they are the fault the bearings were silent while the car was lifted as is often the case they only make noise while under load.
Re: clio diesel
Good point, Terry. In that case yes, tyres could well be making some noise and certain brands are far more vocal than others.
Rich, when my Dad was stationed up in the North East during his national service, he ran an ancient (even at that time) Morris Eight and being an impoverished conscript he couldn't afford tubes or the air to fill them with, so he packed the tyres on the Morris with straw. He only used the car to drive along the coast during his time at that base, so no further than Elgin or Forres probably, but that straw served him well as he managed to avoid buying fresh tubes right up to the time when he was due to come out and needed to drive back down home. Maybe stuffing the Clio's tyres in a similar way would be quieter than running them with gravel inside!
Re: clio diesel
meanwhile in the magical land of the renault clio, i have changed a headlamp bulb..... hour & half to strip & refit the front end & 10 seconds to put the bulb in!
here its against the law to drive a car without a spare set of bulbs, so which prat designed the clio wants his ar#e kicking
Re: clio diesel
An ex of mine had a clio like that. I've had to do several bulb replacements so I feel your pain.
I'm not sure I can hear anything other than engine noise in your clip. assuming you have checked for play in the wheel bearings, does your French fancy have a split drive shaft on one side? if so have you checked for play in the centre drive shaft bearing?
Diff bearings can make a very similar noise to wheel bearings.
Have you had your better half drive the car at a constant speed while you sit in the back and listen to see if the noise is louder on one side or the other?
Re: clio diesel
thanks terry, its the rear wheel bearings that are noisy, i had 2 new tyres fitted & while it was off the ground i had a look & they both are very noisy...
Re: clio diesel
update!! i changed the rear wheel bearings, took it for a little spin & now you can hear the engine....bliss!! wifeys happy too! have made some videos of the bearings as i was dismantling them, will post them when ive worked out how to get them out of the camera
have even treated myself to an obd 2 & can code reader.. just need to get my phd now to work it....
have also ordered a new wing mirror glass, should be here today!!
just need to order a pair for my transit now... i hate clowns
