Cheers John, yes, the prop is the weakest link in the transmission but that should be possible to get round, perhaps with the 360 one as you say, and if need be with the 360 gearbox. I believe there are clio 172 powered variants out there, and I'm also led to believe they are running the standard transmission as its supposedly pretty much a straight swap engine wise (wheres the fun in that
) so am hoping the rest can stand the pain.
Cheers for the pointer to V3M, I've book marked it and will get a good look later,
and yes, I think it will be a case of suck it and see but would be a long term project anyway, as to it happening, if I can get my lad to keep his head in one place for above five minutes it stands a chance
only trouble being he's still at that age where seeing it all through to the end often doesn't happen, but if it is started I'll do my best to make sure it's taken to completion.
