kevin s's blog
kstrutt1
Re: kevin s's blog
#201 Post by kstrutt1 »
Well it has been a productive weekend but not on the car front, the green house is virtually finished, just need to make some staging and add electrics (waterproof socket plugged in garage behind)
Also fired up the log burner which removed all the paint, need to give it a lick of vht fit the door seals, glass and move it in the garage.
kstrutt1
Re: kevin s's blog
#202 Post by kstrutt1 »
Finaly found a couple of hours to play with the minor today, I made and fitted a new a lower a post panel.
Also last week I picked this up
It is a mk2 mx5 hood frame, using this will allow us to fit a mk2 hood with the larger glass window.
kstrutt1
Re: kevin s's blog
#203 Post by kstrutt1 »
seeing as I have just paid to insure it I used tr for the first time in a month or so, no more exhaust leaks after re fitting the downpipes so it sounds much better, oil pressure light came on and stayed on on the way home fortunatelly it has a gauge which was reading fine so it looks like a faulty switch or wiring, othewise it drove perfectly, something to add to the list for over the winter.
kstrutt1
Re: kevin s's blog
#204 Post by kstrutt1 »
Pulled the wire off the oil pressure switch and the light goes out so it seems the switch is at fault, the annoying thing is this was one of the few new parts I fitted 5 years ago with the engine, it has only done around 10,000 miles, the curse of repro parts I suppose.
Also spent some time cleaning the minor floors yesterday ready to paint them, they seem to be covered with some tar like material, most of it came off with a blow lamp, just need to go over it with some thinners to take the remains off then the floors can be painted.
Re: kevin s's blog
#205 Post by tractorman »
kstrutt1 wrote:Also spent some time cleaning the minor floors yesterday ready to paint them, they seem to be covered with some tar like material, most of it came off with a blow lamp, just need to go over it with some thinners to take the remains off then the floors can be painted.
Optimist!!
I cleaned up one of the Landy's old floor panels the other week - plenty of heat got the worst off, nothing shifted the residue! I was fortunate though - the metal was used in hidden places (the seatbox mainly), so it didn't matter too much.
Re: kevin s's blog
#206 Post by TerryG »
Does it burn well? where I have been welding on the RR if I miss a bit of tarry under seal within 4" or so of wherever I am adding steel it ignites making an awful smell.
kstrutt1
Re: kevin s's blog
#207 Post by kstrutt1 »
This seems to be just tar I though about leaving it but it is a good job i didnt becsuse there were patches of corrodion under it.
i will find out how easily it comes off tomorrow!
it does burn well also melts and drips flaming drops on the floor or me!
kstrutt1
Re: kevin s's blog
#208 Post by kstrutt1 »
The floor cleaned up well and has now been painted, but a more serious issue arose tonight, driving the landrover home the brakes completely failed, fortunatelly pumping the pedal restored some brakes and I got home ok, no fluid loss and clamping each of the circuits off had no effect whatsoever so I have therefore concluded the master cylinder is at fault, its the newest part in the system, at approx 18 months old and was supposed to be oem quality, I do worry one day someone is going to die with these crap modern pattern parts. I have ordered a trw part from a reputable supplier, hopefully this will last longer.
Kevin
Re: kevin s's blog
#209 Post by Grumpy Northener »
I suffered exactly the same fate several years ago with a P6 Rover - the master cylinder was stamped Lucas and came from a reptable supplier - It had been fitted to the car 18 months earlier and dispite my complaint to the supplier that the said part had covered less than 100 miles in operation - I got politly told where to go :o They are now on my banned for life listing, along with Nat West Bank, Co op Group, Toshiba, Ford Motor Company, any one on E Bay that reponds to my item for sale with the opening gambit 'Hi M8', Heating engineers that suck air through their teeth whilst shaking their heads prior to giving me a quote for a new boiler and butchers that put grisstle instead of pork in their pork pies - its not an exclusive listing - I keep adding to it and once they on the list they are not coming off it - EVER - apologies for the rant - I'll get m coat
Re: kevin s's blog
#210 Post by JPB »
Grumpy Northener wrote:any one on E Bay that reponds to my item for sale with the opening gambit 'Hi M8'
:twisted: :twisted: :twisted:
Completely with you on that one! The only time when it's acceptable to say "Hi M8" is when you're circling Edinburgh and you turn off the A720 onto a bigger road that takes you in the direction of Glasgow. And yes, any eBay member who says it to me receives that by way of a reply. B'stards the lot of 'em, hanging's too good, etc. :lol:
