Looks like the colour on that Plymouth is most likely one used on the Prowler, it's lovely.
Many other delicious suggestions have been made on another thread:
http://retrorides.proboards.com/thread/ ... ned&page=4
The current thoughts have turned again to rear lights. I really dislike the factory offering, I always thought it could be better. But it's a battle to find anything that suits better. This is the blank template I've been using to mock things up, there's a maximum usable height of 6" to fit new lights into.
There have been some suggestions on other forums until someone cleverly suggested the Alfetta, a car that does look like a Princess from certain angles (no really, it does, but not if you look properly). But to start with you end up with this, which isn't so hot.
Until you remove half the lenses and turn them around and then you get something very appealing.
It's all planning at the moment on this one, it doesn't *need* to happen, but if I'm repainting it would be neat to change the lights at the same time. May go bumperless, may keep the bumpers on, I've not decided on that one yet.
