Torque Wrenchtoo small
I need a torque wrench that can tighten a hub nut to 200 ft lbs. My torque wrench will only go up to 100 ft lbs and a suitable torque wrench is a hell of a lot of money to only use once or twice. If I make up an extension to move the pivot point from the centre of the nut being tightened to a foot further away will this halve the amount of torque required? This could be done quite easily by welding two old sockets a foot apart on a bar. Any other ideas?
Re: Torque Wrenchtoo small
Yes, use a breaker bar and just do it up as tight as you can. This is the sort of torque setting that's known as "FT" in the trade (F***ing Tight).Young Farmer wrote:Any other ideas?
Sorry if that sounds a bit unprofessional, but I bet you it won't come undone....
I used a spring balance and a length of 3/4" water pipe for the job (a long time ago). A couple of jubilee clips stopped the balance's hook from sliding along the bar - which fitted nicely over the t-bar of my socket set.
I'm not sure how high the modern spring balances go - you may end up with a 25Kg balance and a four foot long bar (if you don't mind the mixed units). I'm trying to remember the capacity of the ones I last used for mixing calf meal; which we bought in 25Kg bags and mixed ourselves - it was that long ago!
I have to agree with Luxo though (he posted while was typing) - do it up "dog tight" and it will be fine.
I think the only bolt I have had to tighten over 160lb/ft that my torque wrench can go to is the crank bolt on my v8. To torque it up, I wedged a spanner between the crank and the block and put a 6ft breaker bar on it then stood on the end.
It hasn't come undone in the 5 years or so since I did it.
Weigh yourself and then stand on the breaker bar at the appropriate distance distance from the socket. A 200lb person would stand 1 foot out, a 150lb person 1.3 feet out and so on.
That said, 200ftlb hub nuts can just be done as tight as you like - I just stand on the end of my 2ft breaker bar and job done:)
In a previous life I worked extensively on Audis. The crank pulley bolt on a Audi five cylinder had to be torqued to 450Nm or 350 if using a special tool that was bent to shape for access and was approx 18 inches long. We used a three-quarter drive torque wrench. Certainly on the Audi pulley bolt accuracy was paramount so I would have to disagree with the idea of just doing it up tight. I do have a three-quarter drive torque wrench but I suppose the chances of you being local to me are slim?
West Northants?
West Northants?
Do it up as suggested -- bloody tight -- but add a little Loctite. It wont unscrew itself.
Pavel
Pavel
But this isn't a crank pulley, it's a hub nut. If it requires 200 ftlb then it will almost certainly be a one piece bearing and the torque is there to hold the nut in place, not place a pre-load on the bearing. In such a case "as tight as you can get" is good enough.Minxy wrote:In a previous life I worked extensively on Audis. The crank pulley bolt on a Audi five cylinder had to be torqued to 450Nm or 350 if using a special tool that was bent to shape for access and was approx 18 inches long. We used a three-quarter drive torque wrench. Certainly on the Audi pulley bolt accuracy was paramount so I would have to disagree with the idea of just doing it up tight. I do have a three-quarter drive torque wrench but I suppose the chances of you being local to me are slim?
West Northants?
It might be useful to find out what the actual vehicle is before making all these assumptions.
P45.
P45.
It's a Maxi front hub. I will probably go down the get it bloody tight and a bit for luck route. Don't have to worry about it coming loose as it has a hefty split pin securing it. What about my theory of moving the pivot point a foot away from the hub? will that reduce the amount of torque required by half? would be relatively easy to do as I never throw away old sockets, keep them and weld them on to things that require twisting. Just made a brake adjuster from a split 1/4 " drive socket and a scrap piece of bar.
