More lovely weather means I want to make more effort to get the red Princess MoT ready and make up for lost time. However, I'm beginning to feel like this car is fighting me, all little things but it's annoying when you're so close to being sorted to feel so far away from being ready.
Started small, put the brand new fuses in and a couple of spares in the holder in the fuse box lid.
Then decided to do the speedometer cable because that should be straightforward. I hadn't counted on the cable connector being in a horrible location or that it would be plastered in lithium grease making this the most unpleasant and difficult Princess job I've had to do so far. For refitting there was no way to see what I was doing and the fine thread meant cross-threading was a very real risk, but I prevailed and got it fitted.
Found that the other end plugged much better to the dash and didn't feel as insecure as the old cable so replacement was wise I reckon.
Dropped the dash into place after this but didn't screw it down, I wanted to find out what would and wouldn't work. I now have working hazards but not on the passenger side indicators (but weirdly the side repeater that side does work), choke telltale works, handbrake light works, seatbelt light works. I've been told the random blue wire is the factory earth for the foglights but it won't reach the switch on the loom so I'll be getting creative with connectors and whatever and Dad's expertise in electrics to resolve this. I'm fairly confident the issue with the dash and the lights is now just down to a lack of proper earth and once resolved all will be well.
Next to resolve the lack of firing. Sucked the air out of the fuel line, got a mouthful of varnish-flavoured fuel for my trouble. Pump is working, carb is working, but there's barely any fuel so I reckon I need to put a few more gallons in to resolve this. No visible leaks or wetness on fuel lines or tank so I don't think there's a problem there. What fuel is in the tank is no longer cloudy but is still a horrible colour and odour.
Good, that's a few things ticked and to resolve. I topped up the washer bottle to test it, assumed it was good and put screenwash in and then found it was leaking. Tested anyway and found the washer pump works well and I've got one washer jet of the four to unblock. Removed the bottle no bother and decanted the contents into another container so it wasn't wasted, found it was leaking where the bracket fits and has been fixed previously with body filler and chewing gum, ffs. Tried to remove the washer jet pipe and instead of cutting it free as I've done before, I gave it a bit of a tug and a wiggle and it broke.
Well done me. I should have stopped at this point, but I didn't. Instead I checked the front end to find what appears to be reasonable (if slightly surface rusty) discs and a good amount of meat left on the pads, the brakes were surprisingly good when it was rolled off the trailer and when I drove it up and down the drive so this is reassuring.
Then I checked the track rod end and I now know why the tread on half of two tyres is completely gone. That's another £20 for TREs and £15-30 for tracking to budget for.
Back wheels off, car up on axle stands because I now have an improvised jack handle so I can, and every intention to "just quickly replace the rebound straps".
There's a clip and a roll pin at the top and one on the trailing arm. Top ones were a bugger to shift but they went eventually with a combination of screwdrivers, pliers, hammer, WD40 and swearing.
Thump, thump, tweak, tweak, pin comes loose and... oh.
Well it's only a little hole, maybe the other side will be better.
Never mind, it's just a little bit of welding, the corrosion isn't seriously advanced even though it's likely an MoT fail area. I'll put the straps on anyway and deal with it later. Went pretty smoothly, let the strap take the weight of the trailing arm by lowering the jack carefully and BANG.
FFS.
Downed tools. I'm not touching anything else on this car today, for fear I break something expensive. The straps are brand new rather than NOS and I'm really, really annoyed about them breaking like that. On closer inspection it turns out no strengthening webbing had been moulded into the rubber on the bottom eyelet so as soon as it took the weight of the trailing arm, the strength of the suspension just pulled the roll pin straight through the rubber as though it was made of Brie. I bought the straps so long ago that I can't even return them.
I'll keep plugging away, I'll try and sort the brakes out tomorrow, I didn't get that far today. I don't think this one will be ready in time to go in for an MoT at the same time as the beige one and I'm concerned that I might not meet the mid-May deadline now.
