1972 Triumph Dolomite 1850
Door's a bit on the small side for getting in though, don't you think?
People can always come and go via the door immediately behind the n/s door of the Rover bit of the device. There's also a 3 litre P5-based camper in a similar style, it uses a cut down caravan body (Astral baby Scout or A-line 10 footer perhaps?
Guess what?
I think an MGF electric column would work better, it's family, rather than lumber it with GM shite
Alas it's not a factory fresh minty boxed new one, good guess, but it's not right[/Roy Walker]
mach1rob wrote:.....good guess, but it's not right[/Roy Walker]
http://www.youtube.com/watch?v=Tj7mjb-UPbI
Say what you see
There was supposed to be a local meet on this afternoon, I didn't manage to get down until a bit later on, but it appears the 3 or 4 others that turned up didn't stay long, and had made a move home, it was freezing and as blowy as, as it was down on the quay, so after waiting 10/15 minutes went for a drive through the New Forest. A friend had asked for a video of it out and about (he's from down under you see) so took the opportunity to make a short one while out and about.
Lovely day for it...
As I had to look for my odd noise, while wheel was off, the polishing kit came out. One down, 2 1/2 to go
you only have 3 1/2 wheels? Is your funny noise a wheel speed related thud, thud, thud accompanied with a bit of a vibration?
Funny you should mention that, as it was wheel related!
I managed half of another wheel before cold and darkness stopped play.
