1) Check tightness of the earth screw and check its contact area for corrosion at the timing chain cover end of that long braided lead.
2) Check that [the lead] is still firmly soldered in place where it passes through the battery terminal, ideally drill and tap the tubular section of the battery clamp and secure the braid with machine screws, the holes for which will allow you to flow some solder through the inside of that clamp - none of that lead free crap mind, 60/40 is what's needed.
3) Check the shorter end of the braid that goes to the body earth screw which may be on one of the bonnet hinge mounts or the o/s inner wing just below and slightly in front of the battery tray.
Don't be surprised if that earth braid doesn't follow its intended route, many people will have moved the chain case end to one of the screws that connects the engine mount to the block by now and if they replace the braid, it rarely gets routed through the clamp as original so there might be all sorts of bodges there but generally, the symptom you have shows itself when that wretched long braid works itself loose at some point between engine, battery clamp and bodyshell. This doesn't mean that the battery and/or alternator isn't/aren't in some way responsible but that wretched lead is usually to blame. If your engine has its original water pump cover then that's when sod's law dictates that the alternator will be at fault as that water pump cover means that the radiator needs to come out to remove the alternator pivot bolt where the later wp cover lets you pull the bolt backwards out, no rad disturbing required!
David's spot on about the voltmeters not being especially known for their accuracy but if the meter shows suspiciously low, varying readings when everything electrical seems to be working correctly, then that too is a symptom - along with a randomly poorly charged battery - of poor earths around that long braided cable, especially if yours has an original spec battery sensing alternator instead of the machine sensing type that has by now been fitted to most.
It could be worse: Lucas stuff is eccentric
