#191 Post by rich. »
SEE YA wrote: going self-employed classic car transport, U/K Europe recovery etc in Cornwall .
interesting!
how much for delivery or collection from saumur (france) to mitcheldean gloucestershire?? :idea:
SEE YA
#192 Post by SEE YA »
Go get some quotes and I will beat it ;)
EVERY MILE IS A SMILE
#193 Post by rich. »
i havent bought anything... its just if i do... when i had my jcb 3cx (9 tonnes) delivered it cost me £700....if this helps
mr rusty
#194 Post by mr rusty »
MOT booked for the Vitesse Saturday morning, went down to Wickes Fridsay night after work to get some tiles, and it started pulling to the left when braking......grrrrrrrrrrrrrrr.....most likely a fault on the right caliper- sure enough, damp pad which wasn't moving as it should..a quick strip down showed a mildly tarnished piston, enough to cause a leak past the seal. A clean up with 1500 wet'n'dry, reassemble and bleed, good as new, and pulling up in a straight line. It passed and is still dry but I suppose I'd better replace the seal now.
The initial cause is I believe the protective boot was adrift allowing winer salt in- I have 16P calipers, the boot is an unbelievable pig to fit, you really wouldn't believe how fiddly they are! 16PB's are identical have much better protection, must track some down!
#195 Post by rich. »
after only 8 years of ownership i finally got the winscreen washer motor working on my jcb, it was full of sand :D & im getting all the lights to work again....
#196 Post by TerryG »
Does this mean you are planning some romantic night time digging ;)
#197 Post by JPB »
...and why do you need windscreen washing facilities on a JCB? Is this to keep things nice and clear for making your escape after you've managed to slice through a water main? :lol:
#198 Post by rich. »
:lol: :lol: :lol:
im doing my jcb test (class 4) friday in my own machine so i thought i ought to get it working properly....
#199 Post by JPB »
:shock: There's a test? Cool! Pictures please, if you can take some while you're at it.
#200 Post by rich. »
i will try, but its a written test & another showing i can use the machine & not kill anyone.
