some wiring diagrams with plug pin out showing the wire colours.
There are differences between different states in the USA let
alone the differences between USA and the different countries
they exported the cars.
I have also being trying to either get a company that can remove
the security protocols from my ECU, or get a replacement ecu which
doesn't have those security protocols.
If it has the protocols it won't even turn over.
(Yes I am assuming that the garage hadn't done it before the owner
did a runner)
Well the car has been moved over slightly so I can get around the
car more easily. I think mother is going to say I went to far cutting
back the hawthorn.
The battery tray went back in with a little struggle on the bolts. I did
have problems getting he output shaft speed sensor plug staying put.
With the battery tray out It went on and locked in place. I had the
same problem with one or two other plugs. So far I had no trouble
getting the battery in and out.
As I couldn't find the gasket for the throttle body, I used some gasket
paste before securing it firmly to the manifold. This is when I notice
another little problem with clearance. This time the way the plug gets into
the misfire sensor on the throttle body, it sticked out to the coil pack and
spark plug wires.
I pulled the sensor the one on the left is one off a mk1 neon the one on the
right is the voyager. I will need to get a plug off an old neon engine harness
and change it over so I can use the neon's.
As you can see the voyagers is on the left and has had it. The sockets are
pointing in different directions this why I will be using the neon's old one.
The neon's sensor fitted with no problem, and it is clear to see the improved
clearance.
The spark plug wires have been terminated at the coil pack, but one end on
the plugs needs a new clip so I will need to get some more.
As I pushed myself doing the car today, tomorrow I will take it easy. Aprt from
dropping the tow bar bits off to get welded. So dad can give the hull on hos
boat it's second coat in places.
