How strange
- CustomMoggy
How strange
Mid engined fuel injected zetec morris minor 2 seater coupe in the making!
- Attachments
- 5.jpg (52.45 KiB) Viewed 4242 times
1951 Morris Minor split screen fwd diesel
1961 Morris Minor Ford 1.8 CVH rwd
1969 4 door Morris minor fwd diesel
1970 Morris Minor van fwd diesel
1983 Lola S2000 group C
2004 rover 75
2001 Fiat Ducato
1996 Transit recovery truck.
2004 rover 75
2001 Fiat Ducato
Re: How strange
This will be a thread worth watching.
Re: How strange
I have always fancied fitting the 3.0 from an ST220 to a type 9 and bolting it in to a mog. it goes like stink in a mondeo so in a minor it would FLY!
Which Zetec have you gone for?
- CustomMoggy
Re: How strange
It's the 1.8 black top, using ford original ecu setup & fuel injectors, should map quite nicely, I'll be fitting wheelie bars too, think it may need em. The full build thread is at http://morrisminorowners.co.uk/ftopic4982-0-asc-0.php
2004 rover 75
2001 Fiat Ducato
2004 rover 75
2001 Fiat Ducato
Re: How strange
Have you got a black top ECU on it? How are you managing with PATS?
I avoid the mmoc, i am so annoied with them that i cancelled my membership some time ago.
- CustomMoggy
Re: How strange
pats? I'm using the focus engine, harness, immobiliser, ignition & ecu together, it'll think it's a focus
2004 rover 75
2001 Fiat Ducato
2004 rover 75
2001 Fiat Ducato
- CustomMoggy
Re: How strange
some early photos
- Attachments
- some more rust
- DSC_0871.JPG (36.36 KiB) Viewed 4216 times
- some rust
- DSC_0865.JPG (49.84 KiB) Viewed 4216 times
- coupe chop
- DSC_0016.JPG (42.49 KiB) Viewed 4216 times
2004 rover 75
2001 Fiat Ducato
2004 rover 75
2001 Fiat Ducato
Re: How strange
Is it PATS.. (passive anti theft system) that ford build in to the ECU so requires the sensor ring from the steering column and a chipped key to run. It's been several years since i was doing research in to fitting a 2.0 in to a traveller.
I have a silvertop zetec ECU from a 2.0 Mondeo in the garage so when i eventually get round to building my 2.0 mog i won't have to worry about it.
That looks like you have put a HUGE amount of work in. My hat is off to you, if i found rust holes like that i would have given up. That is going to be a monster when you have it on the road!
- CustomMoggy
Re: How strange
I have all the original wiring, I dont think the key is chipped but if it is it should all work when it's connected up, had a similar system when I built this. It has a 2.4 ltr V6 from an audi A4, this car is on the road now.
- Attachments
- IMG_02232-300x225.jpg (18.95 KiB) Viewed 4197 times
2004 rover 75
2001 Fiat Ducato
2004 rover 75
2001 Fiat Ducato
Re: How strange
If it's a focus it is definitely chipped, If it's a mondeo then they added the chip keys when they launched the mk2 (i think)
That looks like a cool toy.
Are you a fabricator by trade or is this a hobby?
