Volvo 850 Ph2 Fuel Filter Replacement.
Today I replaced the fuel filter on my 1996 GLT. Well overdue in my case! My replacement was a 'Mann' filter. It is a good idea to have a new strap as it is very likely your old one will have rusted badly. They tend to give out where the captive nut sits. Remember to dis-connect the battery.
The filter is under the car next to the fuel tank on the offside, so you will need to raise the rear of the car on ramps or stands. I am very very lucky to have a friend with a 4 poster in his hanger:
That'll be him putting my car up.
Here is the old filter, you can see the 'strap' that holds it in place around the middle. Above you can make out the return pipe, this is push fitted into a 'lug' on the strap.
The pipes, fore & aft are push fit type onto the filter. To release a 17mm spanner can be used as a lever. If you hold the filter with one hand you can use the filter to lever the spanner on, pushing the pipes off. You will get an initial spurt of fuel under pressure, so have a few rags handy.
Here pushing the rear pipe off.
Here front pipe removed. Note resting it 'up' on the return pipe to stop any fuel running out.
Finally the filter removed. Note the 'plug' in the pipe to stop your tank draining! The original strap on mine was a 12mm & was very rusted. Lots of WD40 needed to get it going. It did not break mind. The replacement one, which was a Volvo OE had only a 10mm bolt.
The new filter in place, note the arrow on the filter, points forwards as in direction of flow.
The pipes push back on. I used a 19mm spanner to make sure they went 'gently' fully home.
Tighten up the strap.
Now its time to start up, having re-connected the battery. Turn ignition on and let the pump prime. Mine started on the 2nd spin, just time to get the fuel all the way I guess.
Check thoroughly for leaks. Go for a spin & check again.
Hope this helps & do feel free to add any tips or anything I may have missed.
Thanks.
