Hmm, can't believe i had never considered a Toledo! 1300cc, RWD, sounds like a bit of fun, great looking cars and not too mad on insurance! Thanks for your help, i think the Toledo may be the way to goJPB wrote:If you're never in a hurry to get anywhere, then Dolomite 1300 OHVs are slightly stronger than the 1500s and pretty much as economical as the 1850s, how about the Toledo? 1300cc, RWD, cheap enough to buy and the same as a Dolomite apart from their short boot.
If FWD is more your thing, then Dolomite-shaped 1500s were FWD, changing to RWD for the 1500TC or, prettiest car of the range IMHO, the 1300 (FWD, pictured).
I've covered a total of more than 250,000 miles between my two Dolomite automatics, 191,000 miles in the old Ice blue, 1972 example, more than 40,000 (in less than three years) in my Sienna (also 1972) example. Neither ever failed to get me anywhere, though the brown one did need a head gasket at around 48k and had to be driven around on my spare engine as the original needed to come out and be put under a pillar drill to get the head studs out. Saab specialists have a special tool that usually gets reluctant heads off though, so my method was probably a little radical.![]()
and wow, that's a lot of miles to be done in classics, i take it you know a thing or two when it comes to these cars then?!
