Hi. Took your advice and checked that the chasiss was sound before I try to mount the REAR body tub.
I bought a body mounting kit from Fitchett [as someone advised] and it seems comprehensive BUT
on WHICH of the mounting points are the RUBBER washers[?] fitted please?
Which mountings are the THICK washers for?
There are TWO [2] thick slotted washers.Where are they for?
Thanks in advance.JonP.
Re Mounting Herald/Vitesse Rear Body Tub
Willy Eckerslyke
Re: Re Mounting Herald/Vitesse Rear Body Tub
I'm not sure if this is the correct way, but on my Vitesse I shuffled them around like shims until I got the best fit possible. The slotted washers are especially useful for this as you can press them into place without undoing everything. I didn't use rubber washers on the main mounts, but did use them on the seatbelt irons close to the centre to prevent water leaking in (some chance!).
Thanks Willy will take that on board.As you say re water 'some chance'.J.P.
Toledo Man
Try asking on the Club Triumph forum.
Rarebits4classics is another good source of Herald parts and the owner of that business (Bill Davies) is a Herald guru and can answer your questions.
Another source of information are the factory parts catalogues and workshop manuals. Heritage do these on a CD-ROM/DVD-ROM.
I hope this helps.
I hope this helps.
Toledo Man
1995 BMW 318i (M265 PNC)
HI Toledo Man. Thank you for your info wil try to contact Bill Davies next week. I am only a few miles away from youin leeds.J.P.
