managed to strip the bonnet, the stripes are coming back but wider apart, so the easiest way to get rid was to go back to metal.
P2180131 by
1275midget, on Flickr
nice and shiny - the hole is where the A series carbs walloped the bonnet when the breather got a hole in it... There's a little bulge that goes on top of it.
There's also a hole in the A post:
P2180136 by
but only a small one, It's a pinhole from a weld that's got a bit bigger. I've used it as a waxoyl entrance hole and squirted it all over inside. the area around the hole has resisted battering with a slag hammer (my preferred corrosion detection implement) so I reckon a bit of metallic filler will do that job.
rear deck also investigated, paint's gone weird here and the easiest way to get it off was by stabbing it with a screwdriver. I'll need to take all this off 'cos it had hammerite on it, which really doesn't like cellulose....
P2180135 by
Going to sort the aerial hole as well, no radio so no need.
Also can't stop thinking about putting the fuel filler up there on that nice flat bit...
and also taking the beading off so it's nice and round at the top of the wings.....
more to come after this weekend! (hopefully)
