Does anyone actually know the correct answer? I'm not sure there is a single correct answer?
So, according to the Jaguar manual it says early non syncro gearboxes, should have 20/50 (or in those days 30SAE).
It then says at the end of the chapter later cars with syncro should have EP 90. (or 80/90 these days)
Ok simple? Err no. So EP90 (or EP 80/90 as it now is ) is available in GL4 and GL5, this just means the amount of additives in it (lets not confuse the semi synthetic qualities with the GL raiting).
However use EP90 GL5 in a car with brass bearings and you will have trouble. GL4 is (according to Halfords printed in store guide) gearbox oil and GL5 rear diff oil. I can also see the landrover / Trumpy guys need GL4 not GL5. However im not sure what a Jagaur needs and if it has the bearing affected in the box by GL5... But I now think GL4 is correct for Jaguar not GL5...
Now lets add the curve ball in. When I had my syncro gearbox and laycock overdrive rebuilt (very big and reputable company) the guy said use 20/50 not EP 90 or it will burn the overdrive clutch cone. I have been googling this and many many people are sayign the same thing that laycock overdrive's don't like EP90.
So I go to Pentire Oil's home page... For a MK2 (Mine is a S-type) they recommend their Gear oil 30, NOT EP 90... (for all years including overdrive). Infact they say that you should not use EP90 in a laycock overdrive, and this is from Pentite...
http://www.angloparts.com/images_ap/new ... ochure.pdf
So go to Millers and they say EP90!!!!! (and apparently its good for overdrives!)
http://www.millersoils.net/1_Millers_frame_CLASSIC.htm
So depending where you look each answer is correct. Even GL5...
EP90 GL4
EP90 GL5
20/50 / SAE30
Roll the dice and stick it in....
I was going to use EP90 GL5, but I now believe that is totally wrong. I then thought EP80/90 GL4, but I am now thinking 20/50!!!!!!!!
The answer “just do what it says in the Jaguar manual” I believe is incorrect because they may not have known that EP90 burned the overdrive cones with the shared oil from the gearbox. (they were never built by Jaguar) Also early boxes used 20/50 so why cant that be used on a later box, because we know syncros are not damaged with out EP90...
NIGHTMARE.
Anyone have any cold hard facts?
