TEMP GAUGE
Posted: Thu Mar 19, 2015 8:40 pm
by tolley
I have a landrover 200tdi engine which is fitted into a 3. v8 range rover ,the problem is that the temp gauge is reading high ,does anyone know which sender would put the gauge right ?
Re: TEMP GAUGE
Posted: Thu Mar 19, 2015 11:14 pm
The 300TDI and V8 share temperature sensors (AMR1425) but the 200tdi is different. They are different sizes and fittings so they aren't interchangeable.
The 200 TDI was available in the 92/93 range rover so assuming the sensors are electrically different it may be sensible to find a dash from a scrapped car to swap it out.
I am assuming that the sensor fitted is OK, they only cost a fiver so it may be worth swapping it out just in case as that is less work than finding and replacing the instrument cluster.
