Antifreze
Posted: Mon Oct 29, 2012 6:26 pm
by GMC keith
Hi Hope some one can hellp ,i seam to rember that PC did an artical about antifreze,but cant rember what they recomended for older engines such as my 1979 GMC . Can any one help .
Regards Keith
Re: Antifreze
Posted: Tue Oct 30, 2012 9:42 am
by suffolkpete
Copied to Technical Queries
Re: Antifreze
Posted: Tue Oct 30, 2012 9:58 am
by Luxobarge
Just use more of whatever is in there at the moment.
If it's blue, use standard blue antifreeze. If it's red, use red long-life antifreeze.
Either will work just fine, but DON'T mix them, or your system will end up consisting of sloppy goo that will need to be flushed out.
Cheers :D
Re: Antifreze
Posted: Sat Nov 03, 2012 6:49 am
by alabbasi
Any anti freeze will be fine, just stick some in there. If it's the green stuff, change it every couple of years. If it's yellow, blue or red, it's long life and will last longer.
Re: Antifreze
Posted: Wed Jun 19, 2013 10:49 am
by sierra3dr
Re: Antifreze
Posted: Wed Jun 19, 2013 12:10 pm
by jpsh120
Any MEG antifreeze is generally advised. I bought THIS for mine.
Re: Antifreze
Posted: Sun Jun 23, 2013 7:12 pm
by Ian
We sell Evans Waterless coolant. Never needs changing. Many of our customers ask for it as it eliminates boil over and inhibits corrosion, its really good stuff but even when hot you can take the radiator cap off with no drama (no water, therefore no pressure)
Re: Antifreze
Posted: Sun Jun 23, 2013 8:18 pm
I've seen various of those. I am always loathed to spend that much no it as whenever I have to do work on the car that involves anything to do with cooling I always end up spilling some and what ends up in the bucket under the car is always contaminated with the oil / pas fluid that acts as a rust inhibitor on the chassis.
Re: Antifreze
Posted: Wed Jul 03, 2013 11:57 pm
by sierra3dr
I was reading the other day that tap water isn't ideal,because the parts become coated with minerals
