Triumph Vitesse
Posted: Wed Aug 29, 2012 5:51 pm
by alecweekes
twin carbs on a Vitesse 1600, 1962 convertible... one jet is not working. Can anybody help with advice ? Can I get a service kit or something ?
Re: Triumph Vitesse
Posted: Wed Aug 29, 2012 6:18 pm
by suffolkpete
Moved to Technical Queries
Re: Triumph Vitesse
Posted: Thu Aug 30, 2012 6:42 am
by Richard Moss
Have you tried taking it out and cleaning with compressed air? Service kits can be had from
http://www.burlen.co.uk
Re: Triumph Vitesse
Posted: Fri Aug 31, 2012 8:12 am
by outdoorjoe
Hi although not a vitesse i recently overhauled the twin su's on my spit 1500 so very similar, I would say the current state of your carbs and the extent of your ability would dictate what was the best course of action. You can get ALL parts you need individually or as a service kit and what I found was changing individual parts on twin carbs is throwing good money after bad if time, money, knowledge allow I would highly reccomend buying a complete service kit (genuine SU) available from ebay, moss europe, rimmers etc etc remove the carbs and first thingsfirst clean them thoroughly I mean really thoroughly I used petrol and a toothbrush and took 3 hours!! seperate the carbs and strip, clean some more and recon (add the new parts) one at a time using the other as reference. My spit runs better than ever and the carbs look great and peace of mind they are more relaible.
alternatively you can but the jets individually but ideally as a pair disconnect the old ones from the bottom of the float chamber and the choke mech slide the old oneout and new one in!
let us know what you do and how it goes ay!
joe
Re: Triumph Vitesse
Posted: Sun Sep 02, 2012 8:20 pm
by mr rusty
At that age it'll most likely be Solex downdraughts, unless it's been retrofitted with Strombergs. The Solex carbs are quite complex so I'd be inclined to firstly check that fuel is actually reaching both carbs, if that checks out ok only then I'd dismantle them and give them a good clean, they may not actually need overhauling.
