Corolla serpentine belt noise?
Posted: Sun May 27, 2012 6:21 pm
I'll try to explain the following fault as best I can.
My sister has a year 2000 Toyota Corolla 1.4 VVTi which has just developed a kinda low audible chirping sound coming from under the bonnet. The noise appears every time the driver pulls away from a standing start and on the move, although it isn't present all of the time whilst on the move. There is also a second sound (similar to the chirping sound) when the steering wheel is turned to the left or the right.
The Corolla has power steering and the pump fluid reservoir is at the correct level. There is a small amount of flexing movement in the round pulley that is attached to the tensioner and with the engine running you can actually see the serpentine belt moving slightly from side to side. All the other four pulleys seem fine with no abnormal movement in them.
In the picture below (which is similar to the set up on the corolla), is the slight flexible movement in the round pulley normal or does the slight flexible movement indicate the source of the sound?
Thanks for any help
Steve
Thanks for any help
Steve
