Leather Steering Wheel Cover
Posted: Sat Jun 04, 2011 4:00 pm
I found the Bakelite steering wheel a bit thin and uninspiring, didn't really feel I could grip it safely so decided to get a leather cover.
I looked on Ebay and found KR Classics (Roger and Kim Chaplin 01622 862149, rrogchaplin@aol.com) who import and supply excellent quality covers at many classic car shows and have good feedback.
The cover arrived (eventually, as the size I needed was out of stock at the time) with full instructions and everything you needed to fit it.
Here's how it was fitted:
First the wheel was cleaned thoroughly with warm water and mild detergent (washing up liquid
Then I stretched the cover over the steering wheel and adjusted its position. Placing the seam at the bottom probably looks best - as suggested in the instructions, but if you own a rallye car you might want it at the top.
The threading is fairly straight forward (I asked the wife to do it, as she's better at this kind of stuff), the only thing you have to watch was ensuring it's pulled tight after every stitch.
When you get to the end just tie a tight double knot and tuck away between the edges and that is it. The job took (the Mrs) about an hour, while I supplied refreshments and the entertainment.
The finished product really does look and feel excellent IMHO. I took it for a little test drive in the country just to make sure. Perfect! Cheers
Karl
Karl
