#881 Post by suffolkpete »
I suspect the transmission talks to the engine via a bus system, so separating the two could turn out to be a lot more complicated than just spoofing inputs to the transmission ECU. While there is no problem running a cat with carbs if the fuelling is correct, the reason why injection is universally used is because it's hard to get the fuelling right with carbs. Probably even harder for an amateur. Dispensing with the cat is not on because it will be checked in the MoT if the car was originally fitted with one. The way I would go would be to make the system look like a Voyager and you would have to find a way of talking to the bus. I had a Citroen C5 with about 19 ECUs and a bus system and the only way I could do anything with it was to buy a Chinese knock-off version of the official diagnostic kit. It cost me £85 and I could use my laptop to read and configure everything on the car, and indeed on any modern Peugeot or Citroen from about 1996 to the present, it was impossible to do anything with it otherwise. The Voyager is a much less common vehicle, but it may be worth while searching the internet and all the relevant forums to see if anything like that is available.
tineca
#882 Post by tineca »
Hi Can you not use a megajolt system to get it running?
#883 Post by rich. »
do you know a good witch doctor who can deal with all this ecu Voodoo???
#884 Post by suffolkpete »
tineca wrote:Hi Can you not use a megajolt system to get it running?
You might, but it wouldn't be compatible with the automatic transmission.
#885 Post by TerryG »
A quick google shows them not introducing CAN bus on to the voyager runtil 2007 so some further research may be required.
#886 Post by Mitsuru »
PLEASE read this and follow the links before you start quoting stuff off
google, for every correct answer there are many incorrect answers put
across as correct answers.
http://forums.neons.org/viewtopic.php?f=123&t=351766
http://www.allpar.com/mopar/transmissions/41TE.html
and the user UNA/UNACLOCKER went and did a runner with peoples money
and did a few things to compromise the research.
As for the ecu and reprogramming.
http://forums.neons.org/viewtopic.php?f ... 20e00b5a76
(you will have 33 pages to read through)
#887 Post by suffolkpete »
Life is too short. Can you summarise in a paragraph?
#888 Post by TerryG »
I have found a much cheaper, faster, safer, more comfortable, more practical solution that is from the GM family V6 powered and automatic:
http://www.autotrader.co.uk/classified/ ... ?logcode=p
I bet it will be cheaper and easier to insure too.
#889 Post by rich. »
that does look tempting.... how much has the neon conversion cost so far?
#890 Post by Mitsuru »
Please remove the link or any suggestion to THAT THING!
From this thread immediately.
