Okay it was a little cold, so I did the tidying up ready for tomorrow.
The tube of stainless steel was flattened and put in the car as a tube
it was taking up too much space.
I might need a bigger sheet!
After a previous accident in the tool shed
, I had to do a little
sorting out to even see the floor
even if it is only in one spot.
This ment I could remove the winch from the tool shed to sort it out
prior to using it again, after chewing the rope/cable dragging the car
around previously.
I removed the wire rope/cable from the winch only to find the one I
bought to replace it, is a little too thick to fit in the fixing hole on the
drum. The joy of buying something without checking the correct size.
The trailer was something else that needed attention, one of the wheels
had seized solid with being stood on the garden for a long time. I was
hoping to use the winch to drag the trailer onto the drive to fix it!
The trailer has been stood on the garden for a shorter time period than
the neon has been stood in it's current spot. So it stands to reason the
neon will need to have it's wheels un-seized! As I tried moving the
neon and yes it seized solid so much for leaving the hand brake off
and not in gear.
Dad's Landrover Discovery ended up dragging the trailer around
towards the the drive. Using such a heavy peddled vehicle wrecked my
legs. So there is no way I use it on the public roads, so I'm not insured on
it. I have put the Discovery in front of the garage and the trailer behind it,
the Volvo managed to drag it there and will be used to take the trailers
wheels to garage as the tyres that are on there are well and truly shoot!
So as I have to pop down into town tomorrow with the wheels off the
trailer, #i will also pop to a place I've been told that deals with winches
to see what the correct size winch rope/cable is!
Just so you know how shoot the trailer tyres are, there is no way ou can
read the size or writing on the tyre walls as the rubber is cracked and
falling off the wall!
Sad is bring his boat back from the marina this weekend, and the family
needs the trailer to go to and from the skips to get rid of some of the stuff
we have sorted through from that relatives house clearance!
I can see the welder now, I just need to clear a bit more stuff before Dad
can get to it then weld my exhaust!
