I finally got the expensive piston ring set from Der Franzose which came with instructions as to which went where if I wasn't sure. Some of the old rings did put up quite a fight, others didn't, and while the pistons show their age they're far from knackered so were decoked and kitted out with new rings.
This time, no piston rings were snapped on reassembly. Mike invested in a glaze busting tool for the unit and we tried it out on the Renault's scruffy liners. Worked a treat and they all cleaned up very nicely. Pistons went back in nice and snug and with a few tricks from my brother on how better to use the ring compressor and such we had all four back in the engine in no time. Here's some pictures of just three in situ. I was relying on my camera phone so components look dull when in real life they're actually shiny.
We made sure the correct paper liner gaskets were fitted, that the pistons all pointed the same way (there's marks on the crowns) and that the liners were correctly paired. There does seem to already be signs of good compression, as there was some necessity to rotate the engine while getting everything in and my brother's gloves were being successfully vacuumed into the bores, that bodes well.
With that done it was really a case of reassembly. I didn't get everything done, I'm still a bit unwell and I wasn't in a rush, I'd rather the job be done well than quickly. Got the cam buckets and pushrods refitted, head gasket fitted, head bolts torqued in correct sequence (they'll be retorqued accordingly once the engine has been running) and even got the rocker cover gasket fitted.
On a bit of a roll the crankshaft went in, the exhaust manifold and carburettor were also fitted. I was going to sort the timing and get the chain on but the tensioner has burst into its component parts and doesn't seem to want to stay together. Nothing appears to be broken or missing, it just doesn't seem to want to stay in one piece.
It's looking like a smart little engine now. Looking forward to firing it up when we've finished rebuilding all the various bits and pieces, I'd like to hope it's not going to take another year before it's back in the car but you really never know with the way my life goes.
There's more to update you on with the Rover, I'll do that later/another day.
