Escort Bm Hybrid
Re: Escort Bm Hybrid
engine is pretty much plug and play, litterally, bm to bm, but i might have taco issues, the wiring and clocks are currently 4 pot, and the taco would be reading double.
disregard that last post, wiring is going to be a nightmare
hillmanimpman
right want you done
can't be to hard it all plugs but they should only go in one socket,need pictures i could help as i worked on BMW wiring before as they got two at my college that i worked on them for the last two years going back in september to do other two years i like it that much.
1976 Morris Marina
1975 Austin Allegrohttp://austinallegro.forumotion.co.uk/
1972 Ford Escort Mk1 1100L needs work
1971 Hillman Imp Van,moving very slowly
1956 James Cadet 175cc http://www.famousjamesmotorcycleclub@webs.com
If the rain stays off, when I get home tonight I'm gonna drag the engine out, this should give me clearer access to the wiring. But by the looks of it the loom is fully on the engine, comes of the engine into a box on the o/s bulkhead, I. This box is the engine ecu and the abs ecu. Coming into this box is the hardwired car loom, some of the wires going to the abs plug, and the rest going into the engine ecu. So basically I'm gonna need to know what wires out of that loom do what, and also which wires I'm gonna need for the ews
3xpendable
Bubs I have a PDF Document with the wiring diagram and details for a BMW compact if thats any help? If so, let me know your email address and i'll send it to you.
2019 Ford Mustang Bullitt.
2022 Alfa Romeo Guilia
thetattoostudio@nsworld.com but ive found a few, it's reading them that the issue, it's all gobbeldy gook to me
okily dokily, 27 wires and a conundrum.
This little plug comes of the hard wired loom, and then joins into the engine loom, so what is this powering? and I take it this little take of from that plug (4 wires) to the abs ecu, basicly tells the abs the engine is running, and how fast the car is going? if so, i need to know how to piggy back this to the e36 loom
and then we have this mass of wires, 27 of them, 4 are big thick green uns, well 2 are green, 2 are green and summit, if I can find out what does what here, i'll be 1/2 in ith a chance
okily dokily, seams I need to make this
Unfortunatly this is for an e30, but it now shouldnt be to hard to work out the e36 end from a pdf
but I now have this to work from
thought I'd store it where it's going till I have the subframe
