megadethmaniac
#61 Post by megadethmaniac »
Blow it all 2E it is then, if he`ll deliver!
#62 Post by TerryG »
I think we have started a bidding war! I'm not sure if i can afford to beat MDM's bid as it doubles mine but i may stretch to €2.01 ;)
#64 Post by TerryG »
That looks like a soviet copy of Postman Pat's van. Jag is nice, i have always liked that shape of XJ.
#65 Post by JPB »
Mmm, Very much like the Crayford William (pictured below), I could love one of those.
#66 Post by rich. »
as there are 3 of them you could easily make one into a convertible for sunny days & a hardtop for the slightly wetter weather....
go you know you want to :D
#67 Post by rich. »
this has my name on it.. just need to fix mr2 & sell it.. still no luck with the alternator
http://www.leboncoin.fr/voitures/444278132.htm?ca=18_s
#68 Post by TerryG »
Did you not have any luck with the cheap one on ebay? The offer to order it for you and post it over is still open if you need :)
An SD1 is a good looking car but you should really get the 3500. That way you have the option to fit a turbo to the RV8 or upgrade to a 5.7 from a corvette ;)
#69 Post by JPB »
Buy the Rover! OK, so that engine is a pair of Ligier Ambra vertical twins superglued together ;) but they're a great drive. We had one through the showroom as a P/X when I was still actively getting my hands grubby for a living so naturally, we had to take it for a long test drive after we'd serviced it, just to be certain that it was all OK. During that (40 mile) road test we discovered that the Diesel reached 60 from rest faster than the bog-standard V8 petrol one on carbs did.
If anyone from TVTE is reading this and was wondering how the large number of 11s appeared on the ground in the electricity board's car park one night back in 1990, that would have been me and a colleague checking the above several times as we couldn't quite believe it either. :oops: :oops:
#70 Post by rich. »
thanks again terry. i will be in touch asap...ive emailed the chap about the part but ive not had a response yet...ive done a little bit of research & mine is a 90 amp one with a 4 groove belt & round pin plug.. so rarer & therefore more expensive...
as for the sd1 ive had 4 v8s including 2 vitesse 2.6 & a couple of 2.0 which i would describe the performance as sprightly! ive always fancied trying the diesel, but she who must be obeyed said no.. she wants the traveller..
