#3681 Post by GHT »
Dick wrote: Thu Mar 17, 2022 7:21 pmPeugeot 504 Coupe. Mmm, buy that, it'll give you far less stress than a BL product, or whatever the British motor industry calls itself these days.
Buy Blitish.
#3682 Post by Dick »
#3683 Post by gazza82 »
Dick wrote: Fri Mar 25, 2022 5:24 pm My brother just bought this...
https://www.ebay.co.uk/itm/265595493593 ... SwqwdiJNlt
I had a 2.5Pi Estate .. Mk 1 version in the 70s. I needed something a bit bigger as the Family taxi and this fitted the bill! Maroon with tan leather interior! A full length sun roof was wonderful in the summer .. but leaked onto the rear passengers in really heavy rain!! :lol:
The straight-six purred and the overdrive worked on 3 & 4 using a switch on the steering column so you could say it actually had 6 gears! ;)
Wasn't the most reliable of beasts as the diff exploded after 2 1/2 months! (3 month warranty .. phew!). Then the clutch operating arm snapped ... and that's a hefty gearbox to drop when you only had ramps! The final straw was when we had engine issues though. The crank only has two thrust washers on the rear journal and these suffered when worn as the crank would run on the block ... we only noticed as my Dad mentioned my cooling fan was moving (mounted on crank pulley) as I was pumping the clutch pedal when we were trying to diagnose an odd noise! I had the block welded to build up the wear and ground back to fit the thrust washer ... but even then trying to find someone to do it was a nightmare. While is was sitting around the fuel injection pump (mechanical gummed up). It was here it was sold-on .. to a mate who swapped out the PI for twin carbs. But even he gave up when one of the rear suspension arms split leading to some wild negative camber .. on one side. As he used it to tow his rally car, that wasn't the best style of suspension!
https://www.google.com/url?sa=t&source= ... C7biyDmn7q
#3684 Post by Dick »
Ght, are you still looking for an old caravan??
#3685 Post by Dick »
https://www.facebook.com/marketplace/it ... 025150404/
Prizes for correctly guessing who the famous owner is
#3686 Post by Dick »
https://www.autotrader.co.uk/car-detail ... ar-to=2022
Ght, I just found your dream car for your later years
#3687 Post by GHT »
Dick wrote: Tue Apr 12, 2022 12:45 pmGht, I just found your dream car for your later years
Given the volatile state, what with Putin behaving like his predecessor Ras-Putin, the price of fuel and the availability of oil. Rather than sit in a dead car making brum-brum noises, I shall probably do what a lot of other old farts do, revert back to childhood. Full Size Pedal Car.
#3688 Post by Dick »
GHT wrote: Sat Apr 16, 2022 10:03 pm
Given the volatile state, what with Putin behaving like his predecessor Ras-Putin, the price of fuel and the availability of oil. Rather than sit in a dead car making brum-brum noises, I shall probably do what a lot of other old farts do, revert back to childhood. [url=https://autos.yahoo.com/adult-sized-ped ... CMDMb0p2v-
XleB7hBhb1tMT7QVigeCagPNSmp3smAzysYS8P9QqUFT8iz--Gtlo4UYSpMqp]Full Size Pedal Car.[/url]
You win today's Internet!!
Here is your prize
https://www.facebook.com/marketplace/it ... 996800155/
To collect all you have to do is give the owner some money :lol:
#3689 Post by Dick »
Atodini
#3690 Post by Atodini »
Dick wrote: Mon Apr 18, 2022 9:09 pm https://www.facebook.com/marketplace/it ... tory_share
I never knew these existed
Ahh, the PK Jimp....
There's a few of these about although not too many were built. Based on a galvanised Reliant Kitten chassis with alloy bodywork they were really too heavy for the body ergo a bit underpowered but still great fun!
There's an active Facebook group https://www.facebook.com/PK-Jimp-269894383054559/
John
